Few little tasks before winter
  • rejeep
    • Apr 2010
    • 420
    I am managing two little projects before winter sets in here…
    One thing led to another and I ended up with no Driver door the other day.. (RHD)
    It’s the one door that never closed well, sealed decent, and rattled to hell…
    I decided to pull the trigger and get a replacement.. So I stripped the door off and ordered a new Upper and lower half.. Need to grab some hardware and hinges today as well..
    My second project just turned into an issue..
    I am finally replacing my exhaust manifold on the 2.25P.. It has been cracked since I purchased the Rover..
    I was amazed at how easy every nut was coming off until I got to the rearmost one on the exhaust manifold..
    Rounded and Rusted…
    I’m a bit stuck.. Any suggestions as to methods to remove would be appreciated..
    1971 SIIa 88" NAS Dauntles V6
    1974 SIII 109" RHD
  • KevinNY
    • 484
    A nut splitter.
    • rejeep
      • Apr 2010
      • 420
      think there is enough room in there to get one of thoes?
      I use to have one, but it was HUGE..
      I tried with a vice grip last night, but same issue.. not enough wiggle room..
      1974 SIII 109" RHD
        • 400
        I'v had luck trying a smaller, usually metric, socket hammered onto the nut instead of the correct size. The manifold nuts usually take 1/2" wrench or socket, so I'd try a 12mm, in 6 point, then 12 point.
        • rejeep
          • Apr 2010
          • 420
          I used one of those bolt grabbers that bite in when turned left...
          kinda like a bolt easy out...
          Manifolds are off..
          the joining studs are frozen into the exhaust manifold.. there is no hope I will get them out...
          Cant I just bolt the intake to the exhaust manifold with 3" bolts??
          I mocked it up a few min ago and I cant see any reason why it wouldnt work..
          Meanwhile... when I took the exhaust manifold off the rear most ear of the manifold clunked to the floor...
          I have been driving around with a fully cracked manifold for a lot longer than I thought...
          Im not anticipating it to be significantly quieter, or for that matter much more power... but it has to make some kind of difference to have a good manifold on there...
          1974 SIII 109" RHD
