On a Series III, does the emergency brake boot go inside the opening where the emergency brake lever exits or does the boot go on the out side of the base of the emergency brake lever?
"Iny" or "Outy"
Tags: None
Mine goes inside, and that seems to be what I see the most...which by no means makes this an authoritative answer
Im anxious to hear what others say
A while ago someone posted that it is an inny and that the reason so many folks have a ripped parking brake boot is because they make it an outy and it isn't designed for that much movement.1958 107 SW - Sold to a better home
I have an iny and my wife drives an Audi
According to our Series III guru Les, "iny" is proper as fitted from Land Rover.Comment
Iny. From experience, If its an outy it does rip on about the second pull...
Birmabright Brotherhood
Clint Rankin - 1972 SIII SWBComment
Mine is an inny also, and it hasn't ripped yet. Don't know how old it is, but I'm guessing it was replaced when it was restored in 2000. Using a protective vinyl spray, like areospace 303, or Maguire's Rubber protectant (like armorall, but better) has kept my rubber pieces flexable, even in -20 degree weather. Plus, it makes it look "purrrdy"!Bad gas mileage gets you to some of the greatest places on earth.Comment
According to LaneRover I've got an inny. A ripped inny.73 SIII swb 139 CI, rochester carb
working on:
rear bumper, window glazing, roll cage, paint top, etc... etc... etc....
http://jims73rover.blogspot.com/Comment
