I was painting today (epoxy, then acrylic primer...next will be top coat).
But at first, I was getting globs of paint out the HVLP spray gun. At first I thought it was an air pressure issue (too little), then obviously figured it must be the paint flow rate (too much).
After quite a bit of fooling around, I determined the paint needed a lot of reducer...as in 5:4 (paint to reducer) to flow smoothly and finely.
I've heard of people using 1:1 ratios for paint and reducer, but that's not what I've been told by paint suppliers is normal. Not trying to be cheap, but wanted to see what others have done for their trucks. I was expecting something more along the lines of 5:1, but it was complete crap when I shot it that way. So, I basically ended up spraying paint that was almost the consistency of water - very thin. 1 Coat epoxy, 4 coats acrylic primer.
I'm using quality stuff (PPG). The gun is nothing special - it's Harbor Freight with a 1.8mm tip, but it seems OK.
So, is it "normal" to use this high a ratio of reducer? When I shoot the top coat, same deal? Whatever works works?
