Greetings to all. New member here. I have a 1966 II (or is it IIA) 88", there is fluid leaking out around the clutch pedal. I have topped the resevoir off and cannot seem to generate any pressure. Am I correct in assuming that my problem lies within the slave cylinder, or should I be looking at the master cylinder instead, or both. If it is the slave do I have to take the fender off to get at it?
Any thoughts or advice would be appreciated. Thank you.
