Cold engine problem
  • gelawrence
    • Aug 2010
    • 3
    Cold engine problem
    I am new to this forum because my son and I just bought our first Rover in New Zealand and shipped it to Virginia.. a 1961 Series II, with 43,000 original miles. It is in excellent shape overall, and the engine runs great after it has warmed up, but when the engine is cold it runs rough and dies easily unless we keep it revved pretty high.
    Is there a forum thread that addresses this problem? I tried searching without luck.
    Thanks!
  • LaneRover
    • 1743
    With the Rover's I have owned that usually means I should have used the choke but didn't OR I am using the choke too long.
    It can be very different with each truck
    • albersj51
      • May 2010
      • 687
      I'd check that the timing is right.
      • gelawrence
        • Aug 2010
        • 3
        I should have added that the "cold engine" problem appears as soon as the engine is started, with the choke on. The engine will not start at all unless the choke is on. I have tried playing with the degree of choke, but that does not seem to solve the problem.
        I have not checked the timing.
        • albersj51
          • May 2010
          • 687
          Because i didn't know ill throw this out there about timing:
          Most recommend timing by ear or beer, not via timing light.
          make sure the truck is warmed up
          disconnect the vacuum advance from the dizzy and plug up the VA tube
          Then adjust time until you get a smooth idle (or less ripples in the beer you have sitting on the wing).
          • gelawrence
            • Aug 2010
            • 3
            I like the beer ripple standard for optimum timing. Thanks for your suggestion.
            • kevin-ct
              • 309
              What carburetor do you have?
              Kevin
              04 XJ8
              92 RRC
              02 Benz E320
              95 RRC (sold 5/10)
              72 Series 3 (sold 4/10)
              70 Series 2A (sold 6/10)
              Morgan +8 (sold 8/09)
              72 Triumph Stag (sold 1/08
              • NickDawson
                • Apr 2009
                • 707
                Butch welcome to rover ownership!
                Where are you in Virginia? Richmond here
                I agree with others, I'd start with the timing and check the points. In fact, for $5 you might just want to order a new set from our hosts and replace and re-gap them.
                • Lalo88DK
                  • Nov 2009
                  • 116
                  Sounds like a carburetter problem.
                  • 73series88
                    • Oct 2009
                    • 587
                    mmmmmmmm. beer!
                    runs fine when warm?
                    maybe clogged main jet?
                    67 series 2a 88 RHD sold
                    88 RRC sold
                    60 mga coupe
