Has anyone replaced their rear main seal with engine in? How big of a hassel is it to work around the cross member..any help would be appreciated..thanks
rear main seal
Hi Mark,
I did it on my 88 and its really not a problem. You have to strip everything off the back of the engine to get at those two seal halves but access to the bearing caps is easy as the rear main sits forward of the cross member. Now if you are just trying to replace the seal itself and not the two semi circular pieces too I think life may get complicated. -
Thanks my friend , I ve replace rear mains with the engine out but never insitu..
i really hate to jerk the enginie just for the seal. I assume its just the 2 seals but may have to pull the caps as you mention. make life simple I guess. Probably need to loosen all of them just to drop the rear one yeh.Comment
Apply Silicone Grease MS4 to the shaft and both sides of the oil seal lip
then
Apply hylomar pl32m sealing compound to the seal diameters of the two retaining plates
Considering how bad these rigs leak oil / 37 years later , is there a better solution out there for the grease and sealing compound?
Thanks for your help,
--DerekComment
