I am about to start my engine repairs. This engine has failed crank bearings. I'm confident that all the problems are with the crank bearings. The engine was bored out with new pistons / rings and a replacement RN 8:1 head without many miles on them. The engine developed a knock and when I examined the engine I found a loose flywheel which I think caused the bearing failures.
First question; do I need to remove the head to restore the crank bearings? I do not see a reason that I would have to?
More ?s to follow I'm sure.
