Anyone selling/have a lead on a series?
  • Wander
    • Jan 2010
    • 260
    I was contacted about selling my IIa but I just can't part with her so I'm trying to help the guy find a good series. He is interested in a 88 and a IIa but if it's a good III don't hold back. I don't know what his budget is but something he could drive while doing the little projects/maintenance would be good. The guy is in NC so something in the mid-atlantic/southeast would be great.
    64 IIa 88
    94 Discovery
    06 Toyota 4R (DD)
    ~Matt
  • crankin
    • Jul 2008
    • 696
    Well, I have a 1972 SIII 88...new frame, new paint, paras, new interior, etc...
    All that needs to be done is to replace the seals on the rear.
    Like you said you don't know the budget....but if the price is right, I'll sell.
    Birmabright Brotherhood
    Clint Rankin - 1972 SIII SWB
    • siii8873
      • 1013
      Wander,
      ther is a guy in NC, Nic something, that has been trying to sell what seemed to be a very nice SIII. I was considering it but to far away.
      One small isuue it had was a leaking rear main seal. I'll try to find a contact if interested.
      THING 1 - 1973 88 SIII - SOLD
      THING 5 - 1958 109 PU
      THING 6 - 1954 86" HT
      • BackInA88
        • 332
        Maybe for the right price.
        71 IIa 88 LHD
        Came out of Arizona solid original frame with no rust thru anywhere.
        • IIa trans rebuilt with III gears for full syncro trans but still uses the IIa bellhousing.
        • Dual tanks that switch over from a toggle switch on the dash which also switches the gas gauge over to the tank you are using.
        • New OEM right wing that needs a little work before installing, I have not done it yet because I don't want to loose my nice patina of my 40 year old paint.
        • Spare parts like axles shafts, radiator, trans and t-case parts, some rear amber turn signals, fuel pump, water pump, unused rebuilt Lucas alternator, etc
        • Bulkhead and floors solid.
        • There is a piece of sheetmetal over the right side foot well that looks like at some time in the past it had a different heater and now have a Smiths.
        • Webber card I still have the Zenith
        • Electic radiator fan, pusher
        • New 4 core radiator
        • New window tracks
        • Electronic distributor have original.
        • New seals in the streering box, relay, axles, trans and t-case but I still get a drop when parked. Shifter rods?
        • Swivels balls are nice and I installed new gaiters over them.
        • Engine is not original, it is a military rebuild by BREL and runs great. So it has dual belts and 8 blade fan which I am not running as I have the electric.
        • And I am still running the generator.
        • Overdrive and can run 70+ on the flat.
        • Headliner replaced but not with an OEM material.
        • New OEM washer pump, have you priced one of these!!!
        • Carter electric fuel pump.
        • And there is more and I have reciepts.
        Steve
        71 IIa 88
        01 D2
        • jac04
          • 1884
          There is a Vehicles Wanted section in the Marketplace. That's a good place for the guy to post a wanted ad. If he's looking for a Lightweight and has a bunch of money to spend, send him my way.
          • Wander
            • Jan 2010
            • 260
            Dang Steve, that IIa sounds nice!
            Any pics-heck I just want to see it.
            I will pass these along to the guy, thanks for the replies.
            64 IIa 88
            94 Discovery
            06 Toyota 4R (DD)
            ~Matt
            • rickv100
              • Aug 2010
              • 143
              SearchTempest.com
              Search tempest reveals quite a few 88's for sale around the country.
              I search using LAND ROVER SERIES -DISCOVERY as my search phrase.
              Not quite ready to buy yet(hence no wanted listing) but I am keeping my eyes out for a S2A or S3 LHD 109 ex-MOD. Seems like more 88's then 109's out there at the moment.
              R
              73 xMOD S3 109
              52 M37
              • Eric W S
                • 609
                R
                Why are you searching for Discoveries?
                www.landroverexchange.com, this bbs, and guns and rovers and you have all places you'd need to look for a decent series rover. eblag is dodgy at best....
                EwS
                • rickv100
                  • Aug 2010
                  • 143
                  Eric,
                  I am not searching for discovery's in the search engine when you place a - sign in front of a word it excludes it from the search results.
                  Go to any search engine online and type LAND ROVER SERIES and most of your results will be for Series 1 or Series 2 Discoveries adding the -Discovery excludes them from my results.
                  I also check the sites you have mentioned.
                  Thanks,
                  Rick
                  73 xMOD S3 109
                  52 M37
                  • mongoswede
                    • May 2010
                    • 757
                    There is a website called www.crazedlist.org that lets you search all the craigslist's for items. it might be the same thing as Temptest but in a different format...not sure, have not used temptest.
                    • BackInA88
                      • 332
                      Tell me if this works.
                      A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
                      Steve
                      71 IIa 88
                      01 D2
                      • mongoswede
                        • May 2010
                        • 757
                        Steve
                        • BackInA88
                          • 332
                          Could you see all the pictures on photobucket?
                          Steve
                          71 IIa 88
                          01 D2
                          • Wander
                            • Jan 2010
                            • 260
                            I can, she's a beauty Steve. I like how the dual tanks there own fillers on either side, I think that is the first time I've seen that.
                            I sent the buyer a link to this thread so keep them coming.
                            64 IIa 88
                            94 Discovery
                            06 Toyota 4R (DD)
                            ~Matt
                            • czenkov
                              • Sep 2008
                              • 148
                              Virginia
                              Heres one in Va. If you don't mind RHD.
                              1960 88" SII Pliny the Elder
                              1997 D-90
                              "Fear profits man, nothing"
