Wheel Well Locker on an 88
  • ducttape
    • 175
    I am noticing a dire shortage of storage space on my 88. Not that the two lockers on my old 109 were cavernous or anything, but they did provide an out of sight method for holding lots of little pieces normally thrown in a car's trunk
    Has anyone jury rigged a box of some sort for storage forward of the wheels on an 88?
    Is there a reason I wouldn't want these there? (Inside the wells)
    I do recall seeing an after market box someplace. Similar to what one would see on a rescue truck of sorts. I would prefer access inside though, rather than an exposed hatch along the 'clean lines' of my 88.
    And I am even less keen on these http://www.barebox.co.uk/
    Is it just me, or do these seem silly?
    Thanks!
    1967 Series IIA 88
    Not sure where you mean--Is it something that would span the width of the forward tub floor or do you mean where the tool lockers go; that is, actually built into the wheelwells? Not sure if the last sentence applies 88s, but it does on 109s
    If you mean built into the wheelwells, then that shouldn't be too difficult to fab up. I can post up pics of what they look like from the udnerside if you need
    • meatblanket
      • Dec 2007
      • 98
      Thanks!
      Not silly at all if you drive much with the top off and you don't want all of your belongings stolen from you.
      '55 SI 86
      • ducttape
        • 175
        If you mean built into the wheelwells, then that shouldn't be too difficult to fab up. I can post up pics of what they look like from the undnerside if you need
        Into the wells. I know the 109s have them. I was looking to fab (or better, buy premade!) for an 88. It's not like people buy 88s because they own less stuff!
        1967 Series IIA 88
          • 386
          I fabbed up a box in front of the right rear wheel on one of the 109s, as a battery box. The box itself was actually a galvanized trash can. I attached aluminum angle to the top of the box as a flange, and then attached the flange to the underside of the tub. I have a cover panel held down with screws, but there is no reason it couldn't be hinged.
          • cgalpin
            • May 2010
            • 74
            Maybe one of the landiebox products will work on a SWB?
            • ducttape
              • 175
              http://www.gapanalysisconsulting.co.uk/shop/
              Yes, that is the item (as the other one is outside accessed) However, I didn't think of a galvanized trash can. If one is available rectangular that should do the trick
              1967 Series IIA 88
              • Wander
                • Jan 2010
                • 260
                You could use a galv tub-like people use to ice down beer at a party. If you have a farm supply place nearby go see what they have to work with.
                I've got a small box under the pass side floor that has a hinged cover. The PO did the work so I don't know what the box is made of but it looks like sheet metal. He added treated wood pieces between the outriggers and placed the box there. With the floor mats down you can't see the cover and you can't see the bottom of the box below the sills. He used a piano hinge for the cover.
                64 IIa 88
                94 Discovery
                06 Toyota 4R (DD)
                ~Matt
                • NRutterbush
                  • May 2010
                  • 33
                  Anybody that does heating and air conditioning and sheet metal work should have plenty of galvanized sheet steel around, and the ability to bend it to the size and shape that you want. Putting on a flange and sealing the corners is simple with the right tools, and AC shops have them.
                  Some shops may even have aluminum sheet that can used. I would spend 50 bucks at one of those shops before I tried to cut up a trash can and make something work.
                  • LR Max
                    • Feb 2010
                    • 315
                    This drags up something I've been wanting to do for a long time on my 109. In front of the rear wheel, there is so much dead space that could be used for storage.
                      • 386
                      The galvanized trash can I used for the battery box was rectangular and slightly tapered on all four sides. I picked it up at the local chain building supply store, can fit two Optima type batteries, was already louvered with vents, and the hand hold openings were just the right size for the battery cables and rubber grommets.
                      I plan on installing a potable water tank in the same spot on the other side. The heating duct guys could bend up a galvanized box cheaply, I think. It could be formed to the exact size desired.
                      I would spend 50 bucks at one of those shops before I tried to cut up a trash can and make something work.[/QUOTE]
                      • yorker
                        • 1635
                        One of the Canadian OVLR guys who owns a lightweight added a storage area beneath the floor of the rear loadspace, kind of like in stationwagons of yesteryear. As an added plus when it was closed and a piece of carpet was on top of it no one knew it was there. It was pretty slick. Bad thing was it was difficult to access when the rear was filled with other stuff.
                        Land Rover UK Forums
                        • ducttape
                          • 175
                          One of the sites mentioned here had an under floor compartment. I looked but my muffler goes there. But, I think that might be an option. maybe under the passenger floor. The point is, there really IS a lot of space inside this puppy.
                          1967 Series IIA 88
                          • ShootingCar
                            • Jan 2008
                            • 60
                            Rear cargo area drawer chest?
                            I have been brainstorming on the idea of locked storage for the back of my 88 for a while. I have a truck vault in the back of my Yukon to lock up my guns and to be a raised deck or my bird dog crates and have been thinking of doing something similar for my 88.
                            My first plan was to do a sheet of 3/16" thick aluminum checkered plate that would bridge across from top of the rear wheelwells to form the top of the box and be a seamless raised floor for my dog crates. I realize that when I do this the back area is not accessible for my rear seat anymore, so it's either passengers or the cargo box. Then, I would mount sliding tracks under the top plate and have a sliding drawer made that would have lock on it.
                            Then I found the following site that makes these types of cargo boxes. I have tried to connect with these folks but it's too bad someone doesnt make one these in the US that would fill the area between the wheel wells on an 88.
                            Any of you guys know of a US source for something like this?
                            Jeff
                            Jeff Pearl
                            1969 SIIa 88 ECR Coil Spring Conversion
                            North Central AZ
                            • TeriAnn
                              • 1087
                              Something like this? Except it is over the wheels
                              This is on a Texas Series truck. This is a custom wing box. The owner built an aluminum box and secured it to the underside of the wing above the tyre. The cut in the wing is slightly larger than the opening in the top of the box so the lid can rest on the upper lip of the box. He used a stainless steel piano hinge and flush mounting aircraft latches. He has a box on each front wing. One stores chains and the other is a tool box.
