Zenith 36IVE?
  • BobJones
    • Jun 2008
    • 61
    Zenith 36IVE?
    OK so I have a Solex on my SERII, It's in bad shape, so I was thinking of replacing it with an old Zenith that I have laying around. It is a 36 IVE, the solenoid is gone. So is there any problem using this on my serII?
    • Is there any other difference in this carb
    • can i just plug the hole where the solenoid was.
    Thanks.
  • siii8873
    • 1013
    I plugged the solenoid hole on a 361v and all was fine.
    THING 1 - 1973 88 SIII - SOLD
    THING 5 - 1958 109 PU
    THING 6 - 1954 86" HT
    • BobJones
      • Jun 2008
      • 61
      Thanks.
        • 400
        I think the Solex carb pushes up on the linkage to open the throttle, and the Zenith pulls down. You might have to find the later linkage, or have a really fun and different way to drive the truck....
        IIRC, the Solex and most Rochester carbs push up, the Zenith and Webers pull down, and I had Holley carbs that went both ways.
        • Terrys
          • May 2007
          • 1382
          The Zenith, Rochester, Webber and Carter, all mount at right angles from the Solex. You'll need to get an adapter plate.
          If the Zenith has been laying around a long time, take the cover off and check the body for warpage. Very common. Joint between cover and body won't seal on the gasket. Easy enough to fix. Get a sheet of 400 wet/dry paper, and when your wife goes to the store, put it on the granite counter top and rub the body joint till you have 100% bright surface.
          • siii8873
            • 1013
            Float glass does the same thing as granite for lapping faces.
