Steering Wheel Refurb.
  • Paul and Judson
    • Sep 2010
    • 110
    I am looking to rehab my Series lll steering wheel. It has lost it's black service in all of the usual places and is down to the rough gray material underneath. Any suggestions would be appreciated. Thanks
  • masonater
    • Nov 2007
    • 329
    Eastwood sells a kit that looks pretty nice, I have not used it, but seems like it would do the trick. Kind of pricey...
    1970 Series IIA 109 EX-MOD
    1971 Series IIA 109 EX-MOD
    1982 Mercedes 300TD
    1989 RRC
    1993 D110
    1994 RRC LWB
    1995 RRC LWB
    1995 RRC LWB
    1995 Disco
    1996 GMC 2500 Suburban
    1996 Disco
    1997 Disco
    2001 RR P38
    2005 LR3 HSE
    2006 RR HSE
    • KevinNY
      • 484
      Ike Goss sells a really nice lace on leather cover.
      • Jim-ME
        • 1379
        I agree with Kevin. Go with one of Ike's steering wheel covers.You won't be disappointed.
        Jim
        • thixon
          • 909
          Some black paint will do wonders here.
          Travis
          '66 IIa 88
          • Eric W S
            • 609
            The only way to really restore a steering wheel is to have it re-cast with a new poly. That's what I did. Expensive, but paint and kits just repair the current rot. The rest of the wheel will continue to rot out. Not much is really good at stabilizing it.
            Google steering wheel restorations and do your own research. Covers and paint didn't cut it for me.
            EwS
            • Bertha
              • Nov 2007
              • 384
              I have used the Eastwood kit in the past with positive results. As long as you dremel out the cracks really well and have a lot of patience in sanding, it works really well. You need to coat it with a car grade primer filler and paint for maximum longevity. I have restored several steering wheels over the years using this method and they have held up quite well. Most steering wheel restoration places use the same process and charge you a bundle for labor you could do yourself with a little patience.
              1971 88 (restored and as new)
              1967 88 (the next project)
              • ducttape
                • 176
                I was just thinking on my way home this evening that I should post a thank you to Ike for the cover. I bought it maybe a month ago and it is very, very nice. Excellent quality leather with a great feel and look.
                1967 Series IIA 88
                • JimCT
                  • 518
                  friction tape
                  wrap the wheel first with cork tape for bicycle handlebars then a layer or two of friction tape. Works well and costs almost nothing.
                  1963 Unimog Radio box
                  1995 LWB RR
                  • Mountain132
                    • 79
                    I used the stuff they use to wrap tennis rackets. If you get the foam kind you can wrap it to make the humps.
                    • jac04
                      • 1884
                      You can order a leather cover from Wheelskins as well. Take a few simple measurements and order it. That's what I did.
                      • lrdukdog
                        • 321
                        Ok
                        They are nice, but why not support fellow Rover guy Ike at Pangolin 4x4?
                        Jim Wolf
                        • RoverForm
                          • Jul 2010
                          • 348
                          EwS
                          who did you use for the re-cast?
                          • Eric W S
                            • 609
                            Good pictoral of the process. Owner has a 63? that he used as the mold for mine and is a Brit Marquee guy as well.
                            Did good work for the price (Some folks recasting want well over $1,000). The end result is also dependent on your wheel as well. I got a nice used wheel from Ike at Pangolin4x4 and just bought a NOS center piece for it.
                            Dunsfold has an original for something like $800USD on their site.
