is there a difference between the water temp sending units of a 69 IIa and 74 III? Ever since I put my 69 engine in the 74 the temp gauge has always read right betweem white (cold) and normal. I put my radiator muff on today and went to store. The temp came up to about mid range.
I got home and smelled raiator fluid, truck was hot. Befor the engine swap the temp always ran just shy of mid range, same for the 73 I had.
I'm sure the gauge is not reading correctly,low. I'm going to change thermostat and switch sending units.
