Stainless Steel Grill
  • ducttape
    • 177
    Is it me or does any one else think the plastic on the SIII is really, really tacky?
    FYI, I have nothing to do with this guy. In fact, I don't even have an SIII any more. But I do wish I had seen him a while back.
    David
    1967 Series IIA 88
  • jac04
    • 1884
    IMO, the stainless grille is much more tacky.
    • JackIIA
      • Dec 2008
      • 498
      Great idea. But definitely needs to be '3-dimensional' in my mind rather than flat cutout in the same shape as the original.
      1970 88 IIA
      • ducttape
        • 177
        One of the things I always liked about the II was the metal grill. I think you are right, the stainless wouldn't work. But perhaps galvanizing.
        Oh, heck, I drive a IIa now. I don't care!
        1967 Series IIA 88
        • txffjim
          • Mar 2010
          • 46
          Doesn't this solve the 'eating galvanized metal for breakfast' issue?
          Wonder if he could make one with a grease trap so I could lower my cholesterol.
          73 SIII swb 139 CI, rochester carb
          working on:
          rear bumper, window glazing, roll cage, paint top, etc... etc... etc....
          http://jims73rover.blogspot.com/
          • NickDawson
            • Apr 2009
            • 707
            Awesome!
            I'd also like to see a non-stick version. don't get me wrong, I can cook eggs on cast iron, but really who doesnt love teflon!?
            • msggunny
              • 621
              Just get it powder-coated black.
              04 DII
              08 D3 (LR3)
              • mongoswede
                • May 2010
                • 757
                I vote for the wire version. If you want to do your own stainless, aluminum, titanium etc grill we can always draw one up in AutoCad and give the DFX/DWG drawing to a place that does water jet cutting. Pretty simple...or if its steel you might go to a laser cutter too. Either way lots of possibilities to make your own parts. Could cut something out that looks similar to the wire.
                • TedW
                  • 887
                  Roverdrive makes a really nice galvy replacement grille. Or you could always go with an original wire one from a late IIA.
                  • yorker
                    • 1635
                    Using a frying pan solves that. It also helps keep the scrambled eggs from falling through the grill.
                    Land Rover UK Forums
                    • robert wood
                      • May 2009
                      • 37
                      Roverdrive does not make the nice galvanized grill. Roverdrive only makes overdrives www.roverdrives.com The galvanized metal grill is made by Rocky Mountain now a separate company parabolicsprings.com Both are in West Vancouver hence the confusion
