Anyone know offhand what size the steering wheel nut is? I'm guessing there's a possibility I might not have to shell out $30 for one nut. Probably some weird thread pitch or something though. Still seems a bit steep.
Steering wheel nut
Another mystery thread size has cropped up ... the wheel hold down bolts for the dished hood. I have a pair, but they're in pretty rough shape. Went to a place with a pretty good selection and tried every possibility and no matchy matchy. Any ideas?
(The steering column might be 11/16 fine, but it's an odd size, so I'll have to look further.) -
I think I got mine from DAP ...$10 or so.
Don't know the hood ones- I used some metric ( i think) chevy
truck spring hanger bolts w torx heads until I can find some originals73 SIII swb 139 CI, rochester carb
working on:
rear bumper, window glazing, roll cage, paint top, etc... etc... etc....
http://jims73rover.blogspot.com/Comment
Ike, I agree on paper (ie: that's sure what they look like). But damned if I could get a 1/2 nut threaded onto the bolts I have (though they are pretty banged up), and I also couldn't get a new bolt to thread into the hood. Er, bonnet.
The conventional wisdom seems to be err on the side of "Ike's right." So I'll try 'em again.Comment
yup - dap
page 13
4. Nut . . . . . . . . . . . . . . . . . . . . . . . . . . .(Suffix C onward) . . . . . .552804
working on:
If you have the correct bolts for the spare clamps, it will have an oversized head (same size as your lugnuts, for a reason) and what may look like F'd up threads, about 1/4" up from the end, is an anti-vibration material, set into a hole. You won't get a 1/2" fine (1/2 x20) to thread on, and likewise, won't get a 1/2" x 20 bolt to go into the dish on the bonnet, you'll just mess up the mount.Ike, I agree on paper (ie: that's sure what they look like). But damned if I could get a 1/2 nut threaded onto the bolts I have (though they are pretty banged up), and I also couldn't get a new bolt to thread into the hood. Er, bonnet.
