Hello all,
I was planning on changing the oil (first time) on my Series III in the gearbox, transfer box, and front/rear diffs. At the same time I wanted to do the Fairy overdrive.
So, I got a good tip on here about not overfilling it, and to use the fill plug/dipstick on the top.
I found the following picture of a Fairy overdrive, and see no filler plug on the top as indicated.
The casting looks the same where the picture's arrow points for the oil, just without the plug--solid it is. Is there a variation...I see a plug on the side a little ways down, but am not sure if that is the one? Should I assume if that is the plug to just fill it till oil starts to come out like on the diff/tranny/transfer filler plugs?
Regards,
Julian
Regards,
Julian
