I have two IIAs and, cross your fingers, have had no real electrical problems with them but neither one has any additional accessories hooked to the system. They are pretty much setup as came from the factory. I wish to add a few accesories but do not wish to overload system and begin having problems. Any advice on best route to take? Additional battery etc?
Electrical additions
It all depends on the accessories.
It also makes a huge difference if you are going to try and tie into the original wiring, or plan to run new wiring to the accessories.61 II 109" Pickup (Restomod, 350 small block, TR4050)
67 IIA 109" NADA Wagon (sold)
-I used to know everything there was to know about Land Rovers; then I joined the RN Bulletin Board. -
An excellent question, which can be answered both ways.
1. Depending on the amp draw of the accessory, you can tie into a hot wire coming off the fuse box. But then you are trusting that the 40 year old wiring can take the current without problems.
2. Don't trust the wiring and run new leads from the battery (or solenoid as the case may be) to power your additions.
Personally, I would consider all new wiring for high powered lighting (new wiring back to the solenoid).
I think the small amp could be tied into the current wiring system, provided you use a separate fuse in the line somewhere.61 II 109" Pickup (Restomod, 350 small block, TR4050)
I'm in the process of replacing my entire harness. I found a source in
Portland, Oregon http://www.thehoffmangroup.com/KeepI...products.lasso . They sell a complete harness for 175.00. Very high
quality... better than " Painless " product others have used.
It's was time to get rid of a 40 year old wiring system that will only cause
problems from now on.
Cheers.Comment
