Diesel purge 2.5 na?
  • fred98050
    • Aug 2010
    • 104
    Are you doing a diesel purge on your 2.5L NA from time to time?
    I use this, once a year, on my old Mercedes diesel and it does help, just wondering if there was a reason not to on the Land Rover?
    - Frederic
    sigpic
    1964 88 S2A, petrol 2.25L.
    Weber 32/36 dvg
    Lucas distributor
    2.5 Na Conversion:
    http://gallery.me.com/flangenard#100941
    What I like the most about my Rovers? They've got more problems than I do...
  • Jim-ME
    • 1379
    I've never heard of the stuff. What is it supposed to do?
    Jim
    • Mercedesrover
      • 343
      It's supposed to clean injectors, etc. I've used it on both my 616 and 617 Benz engines....didn't really see a difference in anything but it can't hurt. Diesel Benz guys swear by it.
      www.seriestrek.com
      • Jim-ME
        • 1379
        Sounds like the Opti Lube XPD that I run so that my pump is properly lubricated. That stuff is supposed to clean injectors too. I've Opti Lube for over a year with no bad result.
        Jim
        • fred98050
          • Aug 2010
          • 104
          Just checked your website, I love the 616...
          That you have been my diesel engine of choice but looks like the conversion wasn't that easy...
          Great job and thank you for sharing.
          sigpic
          Weber 32/36 dvg
          Lucas distributor
          2.5 Na Conversion:
          • fred98050
            • Aug 2010
            • 104
            Jim
            Keeps injectors clean and removes carb deposits. It really helped my old 617 engine, starts better, does not smoke (as much) etc... Never used it on a non-bosch injector pump though....
            sigpic
            Weber 32/36 dvg
            Lucas distributor
            2.5 Na Conversion:
            • Mercedesrover
              • 343
              Originally posted by fred98050
              Just checked your website, I love the 616....
              The 617 turbo in the 109 is even better.
              www.seriestrek.com
              • fred98050
                • Aug 2010
                • 104
                Oh boy!
                That, is looking really really sweet!!
                Any videos?
                Is that a special bulkhead in the 109? Same adaptor plate than for the 616?
                sigpic
                Weber 32/36 dvg
                Lucas distributor
                2.5 Na Conversion:
                • Mercedesrover
                  • 343
                  2.6 NADA bulkhead
                  It's mated to an NP435 4-speed so it's a different adapter.
                  www.seriestrek.com
                  • yorker
                    • 1635
                    Jim
                    It is kind of different, you unhook your fuel lines and run it straight:
                    Land Rover UK Forums
