New gas tank - lesson learned
  • NickDawson
    • Apr 2009
    • 707
    So...when you get a new sales tank, and there is that rubber cap over the large hole....
    ah...
    don't drop that rubber cap into the tank.
    That is all.
  • crankin
    • Jul 2008
    • 696
    Haha.
    Birmabright Brotherhood
    Clint Rankin - 1972 SIII SWB
    • cousindave
      • 192
      Sounds like you're having cousindave kind of day!
      • RoverForm
        • Jul 2010
        • 348
        any insight on how to get it back?
        also, can you describe the look on your face as soon as it dropped into the abyss?
        • NickDawson
          • Apr 2009
          • 707
          Here's the plan:
          Im going to take a 4 ft section of 1" wooden dowel and apply a liberal dab of 1 minute epoxy to the end and smush it on the the rubber cap. Once its dry, hopefully I can just pull it out. Plan B involves getting it close enough to hit it with a propane torch. Plan C involves plan B, only with me calling the fire department and then rovers north for a new tank.
          Ask my wife about the look on my face after a challenging work day and a long business dinner. It was somewhere between disgust and defeat.
          • RoverForm
            • Jul 2010
            • 348
            so sorry. i think you'd be alright if you could get your hands on some forceps as long as your arm...
            • NickDawson
              • Apr 2009
              • 707
              Woot! My dowel and epoxy method worked on the first try!
              New tank is mounted and the Rover rides again! (but for some reason I didn't need 90% of the little trinkets that came in the tank replace kit from our hosts).
              • kwd509
                • Aug 2010
                • 180
                I'm trying to get a fix on the gas tank hardware issue too....... when I pulled the tank from my 64 diesel it was in good shape externally (inside will need treatment) but there was minimal hardware, five nuts and bolts with washers..... that's all- mounting it directly to the chassis.
                What were the 90% you did not use? And what purpose are they purported to serve?
                • NickDawson
                  • Apr 2009
                  • 707
                  (mine had 6 bolts)
                  Thats just it, I dont know. Some brass plates, some large funky bolt (not the drain plug), some random screws (every screw I needed came already in the new tank)... a strange 1" x 3" L bracket... and two rubber grommets. I dont see any of that stuff in the green bible.
                  • artpeck
                    • Dec 2009
                    • 368
                    Did you have extra rubber grommets? Mine mounted with the rubber grommets on the mounting bolts in between the flanges.
                    And congratulations on the dowel and epoxy setup. I was skeptical but now that is another trick to tuck away for when needed.
