I just bought a 1958 series truck, the box is a bit beat up on the rear quarter panels are there replacement panels available? If not I might just put a flatdeck on it.
1958 Series II pickup
1968 Series IIA
1987 D90 Kid's project
Tags: None -
not sure if there are any panels available. You might have better lucky just replacing the whole tub structure..it will certainely be less work then having to drill out all the rivets and spot welds and then doing all the reattachement work. -
rear tub
how much work is there in replacing the rear tub? I will take a couple of pictures of the rear damage and post them to see your more experinced opinions as to which route to take. Thanks in advance1968 Series IIA
Its still a fair amount of effort to swap tubs but its all removing bolts and then replacing them and realigning body parts. I took my 73 body down to the frame using an assortment of wrenches, sockets, and drill bits. The chordless drill came into play when a bolt was siezed...it was faster and easier to just drill the heads off a lot of bolts.Comment
