Add a "flasher" dash light to a 69
  • mrdoiron
    • Dec 2009
    • 446
    I find going from vehicle to vehicle, I often forget to turn off the turn signal on the Ser II (ser III has a dash light indicator), so several streets later I realize the blinker is still on... less annoying for me than others on the road I'm sure.
    Anyone know of a quick and clever way to add a dash light ?
    thanks, mike
    1961 Ser IIa Hybrid Defender
    1969 Ser IIa Bugeye
    1998 Disco - ex wife :-(
    2010 RR Sport Supercharged
    Run a wire from the the green/white wire (coming from the flasher switch) to the (+) side if a 12v LED or incandescent lamp, then from the (-) side of the LED or incandescent lamp to ground for the left turn signal dash light.
    Do the same with the green/red wire for the right.
    • Terrys
      • May 2007
      • 1382
      or you could use the third terminal of a three prong flasher unit, that's what it is for.
        Interesting....!
        • mrdoiron
          • Dec 2009
          • 446
          great - appreciate the solutions.
          Terry - on the 3 prong flasher solution, I assume the existing one doesn't have a 3rd prong (need to check) , so this means replacing the existing one, and run a light from the 3rd term to the dash ?
          cheers, mike
          1969 Ser IIa Bugeye
          • ducttape
            • 177
            as a slight sidebar, is there an equally simple solution for an emergency flasher setup?
            1967 Series IIA 88
            • Jim-ME
              • 1379
              Try Rocky Mountain Products. They have a kit that includes 4 way flashers and a 12V socket mounted in a panel. IIRC it's about $60.
              Jim
              • Jim-ME
                • 1379
                Sorry about that I misread the original post.
                Jim
                • mrdoiron
                  • Dec 2009
                  • 446
                  thanks, I went this route and works fine (into the hazard light).
                  cheers, mike
                  1969 Ser IIa Bugeye
                  • Terrys
                    • May 2007
                    • 1382
                    cheers, mike
                    Without digging out schematics, I (don't have a 2A at the moment) recall that the 2A uses a 3 prong flasher, the 'I' terminal feeds the light in the turn signal unit. The S3 is much simpler; power goes to a 2-terminal flasher, then to the stalk, which selects the side of choice, the indicator being tied to the same line as the F&R blinkers.
                    The self cancelling unit supplied on 2As is rebuildable to a point. Someone had new rubber wheels too. Signal Stat makes a unit similar in appearance, but is not self cancelling, but does have a hazard flasher switch included. It's necessary to use the specific 3-prong flasher they list as it will trigger the indicator light, whereas a regular one will not.
                    This is just trivia if you've got it wired up already.
                    edit: Ike has the new wheels for the original turn signal units
                    • Enigma
                      • 88
                      Rather than a dash light, I got 2 red led lamps with a threaded housing (about 1/4 in Diameter) and mounted them at the top left and right corners of the defroster housing over the windshield motor. I connected them with fine speaker wire to the harness for the signals by the radiator. Easy to see
                      from my driving position.
