Series III Dash Repair Or Replacement
  • artpeck
    • Dec 2009
    • 368
    I know this doesn't apply to those in the all metal set but for those S3 owners out there I have a question about dash repair.
    The top pad is cracked and in other places the vinyl is ready to fall off. Not a big deal but cosmetically annoying as I restore other parts of the truck. Our host lists the dash pad as NLA. I am curious if anyone has ideas on a source for a replacement or repair alternatives. I did find one shop in southern CA that specializes in this for vintage restorations but if anyone else has ideas they would be much appreciated. Thanks as always.
    • 390
    I covered my old cracking upper dash pad with new vinyl. I cut off the jagged edges of the old vinyl, and filled all of the gouges with spray foam. I cut the spray foam flush with the existing dash and covered the old vinyl with a thin layer of batting. I stretched the new vinyl over the old dash, and secured the one edge with the original half moon clips that I had removed previously. The other edge I glued down. I used spray glue to secure the batting to the old vinyl, and the new vinyl to the batting.
    This is a pic of the covered dash. Not the best pic, sorry.
    '02 Disco II SD
    '80 SIII 109
    '75 SIII 88 V8
    '68 SIIA 109 V8
    • Walker
      • 94
      I pulled my old dash pad off and took it to a local upholstry shop. They replaced the old cover/padding and used an industrial grade adhesive. I live in the San Joaquin Valley of Calif (105 degrees/28 degrees) and the rig stays outside. 5 years ago and no cracks, pulling, ripples, etc. Cost was about $225. Well worth it to avoid the repeated agravation I am known for.
      Art
      • artpeck
        • Dec 2009
        • 368
        Really helpful. Thanks. I am a little reluctant to tackle this myself as I can't even adequately wrap a Christmas present. The picture looks great and I hadn't even thought of the upholstery shop idea. Worth investigating. May I ask where you are in the valley? I am in the SF area.
        • Firemanshort
          • 282
          I just saw an advertisement on the Bring-A-Trailer website for Just-Dashes
          They are located in Sunny California. They do custom restoriations.
          I recommend you send you dash there and they report back to us on how it comes out. Mine has a few small cracks now - and will likely need life support in a few years.
          Firemanshort
          1980 Stage One
          • artpeck
            • Dec 2009
            • 368
            That is the place I found in so cal. I will call them and report anything relevant I find out.
            • jac04
              • 1884
              Just Dashes is very expensive and they tend to take a little "artistic liberty" with most dashes. I have researched them for possibly restoring a dash pad for my 68 Camaro. For a SIII, I suggest the methods that others have suggested or bring it to a local upholstery shop who will essentially re-skin the dash pad.
              • leafsprung
                • 1008
                may be some NOS dashes available soon
                  • 390
                  Im no upholstery guy, but the recover of the upper dash pad is a pretty simple job. There are no complex curves, like on the lower dash, and it is basically a wrap and glue repair. Once the dash pad was off of the truck, the entire job was completed in only a few hours and cost under $40.00.
                  Jeez, if your upper pad is already bad, why not just try to fix it yourself? If you do mess it up too badly, maybe Ike can find you a NOS one!
                  • artpeck
                    • Dec 2009
                    • 368
                    I may try to. Was simply trying to understand alternatives and alternative approaches to the repair. Thanks for the info.
                    • Walker
                      • 94
                      Art - I am in the Fresno area. The shop I used is very reasonable and make a quality product Without artistic license.
                      Also Art
