Parking light removal
  • Alk-3
    • Mar 2009
    • 185
    I have a 67 land rover and I can't figure out how to remove the front parking light lens to change the bulb.. Any help? I don't want to break anything trying before I ask.
    Which variant?: http://www.roversnorth.com/store/c-1...nt-lights.aspx
    • Alk-3
      • Mar 2009
      • 185
      It's the One labelled 'series 11 11a through 1970'
        • 389
        The chrome ring just sits in a lip on the rubber base, and the ring keeps the glass lens in place. You can take a small screwdriver and lift the rubber over the outboard edge of the ring, slip the blade under the ring and lift out the ring. Do the same with the lens, but be careful you don't chip the glass..... If your rubber is old and brittle, it can easily chip and crack.
        • Alk-3
          • Mar 2009
          • 185
          Thank you. That's what I suspected. I'll give it a shot and try not to ruin the rubber.
