Bolts
  • albersj51
    • May 2010
    • 687
    #16
    Great thread! I am taking my 67 S2A down to the frame in a few weeks and I want to replace all of the body To frame bolts (have a feeling I'll be destroying a lot of them). Mountain132 was kind enough to email me the PDF . As I was creating a file of all the bolts to order I realized s3 bolts may differ from s2a bolts. Can someone confirm that LR didn't change bolts/threads from models? Also, if anyone already has a list of what I would need that would be awesome! Mainly want to make sure I have anything that connects to the frame or anything likely to strip or require cutting off. If not, I'll post my file for general knowledge. Thanks!
    • mrdoiron
      • Dec 2009
      • 446
      #17
      Originally posted by albersj51
      Great thread! ......
      Agreed, part of the beauty of this site is discovering what you didn't know you didn't know. Thanks for lending your homework boyz...
      mike
      1961 Ser IIa Hybrid Defender
      1969 Ser IIa Bugeye
      1998 Disco - ex wife :-(
      2010 RR Sport Supercharged
      http://mikerovers.shutterfly.com/
      • albersj51
        • May 2010
        • 687
        #18
        OK, attached is an Excel file listing bolts, nuts, washers, screws, etc from the Belgian manual. This is not EVERYTHING, just what I think I need to remove/replace as I remove the body. Does this look like a good list? Also, I expected to see British Fine Thread type of bolts, but all are UNF and UNC...is this right for a IIA? Lastly, anyone know the length of the bulkhead to chassis bolt?
        Give the file a look and let me know if it looks "right" or not. Thanks!
        • albersj51
          • May 2010
          • 687
          #19
          File wouldnt attach so I did a copy/paste...
          Clutch Pedal assembly
          QtyBolt, 1/4" UNF X 1" long1Nut, 1/4" UNF1Bolt, 5/16" UNF X 7/8" long6Spring washer6plain washer6Drive screw6Fuel TankScrew, 5/16" UNF X 3/4" long6Plain washer12Spring washer6Bolt, 5/16" UNF X1 1/2" Long (Shouldered)2Washer2Rubber Bush4Nut, 5/16" UNF2Stiffener Plate2Spring washer2Bolt, 10 UNF5Plain washer5Large Plain Washer5Spring Clip5Spring Washer5Nut, 10 UNF5AcceleratorBolt, 1/4" UNF X 5/8" Long4Spring Washer4Nut, 1/4" UNF4Pinch Bolt, 1/4" UNF X 5/8" Long5Plain washer10Nut, 1/4" UNF5Bolt, 1/4" UNF X 1/2" Long2Spring Washer2Nut, 1/4" UNF2Bolt, 1/4" UNF X 3/4" long2Spring washer2Plain washer2Nut, 1/4" UNF2Pinch Bolt, 5/16" UNF X 7/8" Long1Nut, 5/16" UNF1Stop Bolt, 5/16" UNF X 1 1/8" long1Plain washer2Nut, 5/16" UNF2Bolt, 1/4" UNF X 1 1/4" Long1Plain washer2Nut, 1/4" UNF1Hand ThrottleBolt, 10 UNF X 5/8" long3Radiator PanelBolt, 1/4" UNF X 5/8" Long13Spring Washer13Nut, 1/4" UNF13Brake PedalBolt, 5/16" UNF X 5/8" long6Spring Washer6Plain Washer6SteeringBolt, 5/16" UNC X 2" Long1Spring Washer1Set Bolt, 5/16" UNC X 3/4" Long4Bolt, 5/16" UNF X 3 3/8" Long6Plain Washer6Plain Washer6Spring Washer6Nut, 5/16" UNF6Bolt, 1/4" UNF X 1" Long3Shim Washer3Plain Washer3Spring Washer3Nut, 1/4" UNF3Self Lock Bolt, 7/16" UNC X 1"2Plain Washer4Nylock Nut, 7/16" UNF2Bolt, 5/16" UNF X 7/8" Long4Plain Washer10Nut, 5/16" UNF4Screw, 5/16" UNF X 3/4" Long2Spring Washer2Plain Washer2Screw, 5/16" UNF X 3/4" Long2Spring Washer2Plain Washer2Bolt, 1/4" UNF X 7/8" Long2Spring Washer2Plain Washer2Chassis FrameBolt, 3/8" UNF X 3 1/2" Long4Self Locking Nut, 3/8" UNF4Bolt, 3/8" UNF X 2 3/4" Long8Plain Washer8Self Locking Nut, 3/8" UNF8Bolt, 1/4" UNF X 5/8" Long3Spring Washer3Nut 1/4" UNF3Rad PanelBolt, 5/16" UNF X 1 1/4" Long3Plain Washer3Rubber Buffer3Screw, taptite 1/4" UNC X 1/2" Long2Spring Washer2Plain Washer2BulkheadTie Bolt, 1/2" UNF2Plain Washer2Nut, 1/2" UNF2FloorBolt, 1/4" UNF X 3/4" Long4Spring Washer4Plain Washer4Nut, 1/4" UNF4Rear TubBolt, 1/4" UNF X 3/4" Long2Plain Washer2Fan Disc Washer2Nut, 1/4" UNF2Bolt, 1/4" UNF X 5/8" Long4Spring Washer4Nut, 1/4" UNF4Set Screw, 5/16" UNF X 1 1/8" Long4Bolt, 5/16" UNF X 7/8" Long10Fan Disc Washer14Nut, 5/16" UNF10DoorsScrew, 5/16" UNF X 2" Long8Spring Washer8Nut, 5/16" UNF 8Screw, 5/16" UNF X 1 1/2" Long8Nut, 5/16" UNF 8Bolt, 1/4" UNF X 3/4" Long6Spring Washer6Plain Washer6Sill PanelBolt, 1/4" UNF X 3/4" Long8Plain Washer16Spring Washer8Nut, 1/4" UNF8Bolt, 5/16" UNF X 3/4" Long4Plain Washer4Spring Washer4Spire Nut, 5/16" UNF4Bolt, 1/4" UNF X 5/8" Long4Plain Washer8Spring Washer4Nut, 1/4" UNF4Bolt, 1/4" UNF X 5/8" Long12Plain Washer24Spring Washer12Nut, 1/4" UNF12Bolt, 1/4" UNF X 5/8" Long2Spring Washer2Plain Washer4Nut, 1/4" UNF2Bolt, 1/4" UNF X 5/8" Long4Screw, 1/4" UNF X 5/8" Long (MUSH HD)2Plain Washer4Spring Washer6Nut, 1/4" UNF6TubBolt, 1/4" UNF X 3/4" Long2Plain Washer2Shim2Fan Disc Washer2Nut, 1/4 UNF2Bolt, 1/4" UNF X 5/8" Long4Spring Washer4Nut, 1/4 UNF4Set Screw, 5/16" UNF X 1 1/8" Long4Bolt, 5/16" UNF X 7/8" Long10Fan Disc Washer14Nut, 5/16" UNF10Fuel CoverScrew, 2BA X 1/2" long2Plain Washer2Spring Washer2Nut, 2BA2Drive Screw4Washer4Bolt, 1/4" UNF X 5/8" Long8Plain Washer8Spring Washer8Nut, 1/4" UNF8Bolt, 1/4" UNF X 1" Long1Plain Washer2Spring Washer1Nut, 1/4" UNF1
          • Mountain132
            • 79
            #20
            The SIIA and SIII parts manuals indicate which thread (BSF/UNF/UNC) is used over certain model years. For example the shackle bolts which attach the leaf springs to the frame may be BSF over a certain period of time then switch to UNF for later models. What they don't often show is the length and diameter which the belgian manual shows.
            I would think that in any application where you are replacing both the bolt and nut that you could use any thread pitch as long as the diameter and length are consistent with the belgian manual. In applications where you need to mate a new bolt to a threaded opening such as the drive flange, then you need to make sure to get the right one. As you disassemble, keep the old bolts with the component even if you are going to replace them, it makes this process easier.
