Is this alternator correct?
  • futurafalcon
    • Dec 2010
    • 10
    I own a '71 2.5 petrol, negative ground 2a running with a generator that I am converting to an alternator.
    I bought a Delco 10SI today part number 321-39 but could not figure out which clock postion for the plug in.
    In the alternator pictured is the plug in the right place?
    thanks
    Last edited by futurafalcon; 12-04-2010, 05:27 PM. Reason: had trouble posting pics
    1971 IIa 88
  • stomper
    • Apr 2007
    • 889
    I can't answer the question, but try reading this article.
    • futurafalcon
      • Dec 2010
      • 10
      http://www.expeditionlandrover.info/...ternators.html
      I just read it, thanks for that.
      I have the Pangolin 4x4 mounting brackets on order so I would like my alternator clocked in the 12 o'clock position. Is it?
      I need advice on how to determine what the 12 o'clock posiiton is?
      1971 IIa 88
      • jac04
        • 1884
        The alt pictured will work, but the plug will be pointing toward the wing. You may need to lengthen your wiring. With Ike's mounts I used an alt with the plug at 12 o'clock = NAPA 1N-4011A.
        • printjunky
          • 325
          To clarify "clock position," looking at the back of the alternator with the threaded adjustment ear pointing up, the position of the plug spot (sense/light wire) is the clock position. ie: jac04's 12:00 alternator has the plug on top. MUCH easier to plug in than mine at 6:00!
          • futurafalcon
            • Dec 2010
            • 10
            Thanks jac04 and printjunky, for the picture and definition of what clock position is. Cheers
            I can take it back to the parts store and do a swap.
            I've even read it is not too difficult to rotate the rear housing to change clock position on some alternators. I'm not sure if that is the case with Delco 10SI's though.
            thanks again for the advice and info fellas
            1971 IIa 88
            • jac04
              • 1884
              ^^Yes, you can re-clock the 10SI very easily. Usually the instructions in the box cover re-clocking the alternator if required.
              • futurafalcon
                • Dec 2010
                • 10
                Excellent, I'll give that a go.
                Two more questions relating to the pulley and belt.
                1. I'm confused about the pulley. I have read to get a double pulley but I do not know why as there is just one belt. I guess it could be to get it in proper position.
                Do I need to get a double pulley? If so what size?
                2. Can I run the same belt in not what do I get?
                1971 IIa 88
                • LaneRover
                  • 1743
                  A double pulley is to get the positioning right. Most guys get their hands on a Rover military double pulley
                  Yes you can use the same belt - actually come to think of it I don't know that for sure but I am pretty sure you can.
                  • Donnie
                    • Apr 2007
                    • 287
                    thanks
                    Re clocking is easy, just remove the 4 8mm screws that hold the unit together.. carefully tap the housing , but do not allow the units to seperate more than 1/16 of an inch..You can then turn the housing into whatever position that you need.. the 4 bolt holes are evenly spaced
                    • jac04
                      • 1884
                      You should be able to run the single pulley. I ran it that way for a little bit.
                      The belt is a Dayco TopCog 15495.
                      • futurafalcon
                        • Dec 2010
                        • 10
                        I re clocked it to twelve. To make it clear some casting I had to separate more than 1/16 of an inch though - to a 1/2 inch max at one corner.
                        It spins free, doesn't make any loose parts sounds when I shake it so guess it's good to go.
                        Is there a bench test to see of the brushes are still in the right place?
                        1971 IIa 88
                        • Donnie
                          • Apr 2007
                          • 287
                          Were you doing this on the bench or on the truck...Always do this on the bench...1/2 inch is a lot . You may have dropped a brush. There is no way to bench test w/o pulling the rear case...If you are feeling insecure . I would check it before running it on the truck....send me an evening phone # & I will walk you thru it. Don
                          • galen216
                            • 236
                            I too run the single pulley. No need for a double pulley. With Ike's bracket it should line right up.
                            74 SIII
                            96 Disco SE-7 5 Spd.
                              Hmm...Why can't one test it electrically, with a continuity tester/Ohm meter without opening the case?
