Best Locking Hubs for '71 Series IIA
  • RoverTrails
    • Sep 2009
    • 12
    Hi there, we are looking to replace the existing Selectro hubs and found Mile Marker, Superwinch and AVM brand that have a model that will fit the '71 Series IIA. Would like Warn but not finding a specific model that will fit. Does anyone have any experience with the mentioned hubs and if so a preference?
    Thank you for your time.
  • 73series88
    • Oct 2009
    • 587
    i have warn locking hubs on my 73 88 and there great no problems
    aaron
    67 series 2a 88 RHD sold
    88 RRC sold
    60 mga coupe
    • LaneRover
      • 1743
      Just in case you don't know.
      You can go with just drive flanges, you don't have to have locking hubs on the front axle.
      • stonefox
        • Jul 2010
        • 450
        I agree, I think. Maybe I'm wrong but it already is in 4x4 the only thing the hub "unlockers" do is take it out of 4x4 to free wheel. I was told by RN staff that in free wheel the axle shaft was not spinning hence not lubbing the axle shaft ie. premature wear, thats why they were not installed from the factory. They are great if you are pulling your truck across counrty behind your camper , but not to be left turned out for long periods of time. Please someone correct me if I'm wrong because I was talked out of keeping mine on my truck.
        Sean
        1963 88'' IIa daily driver
        1970 88"
        1971 88"
        authenticstoneworks.com
          • 390
          I have Superwinch hubs on my 88 and they have been troublefree. In the summer I ran with them unlocked for several weeks until I heard chirping from the swivels. I now keep them locked all of the time. My 109 had AVM hubs, but I removed them due to continuous seepage, even after new seals and gaskets. A traded them to a friend for stock drive flanges.
          It always seemed that when I really needed 4wd NOW, the hubs were unlocked....
          I really didn't notice any difference in gas MPG locked or unlocked.
          • rwollschlager
            • Sep 2007
            • 583
            Warn M-11 should be what your looking for. IIRC they are no longer made but you can find a used set in good condition if you keep your eyes peeled. It is ok to drive around town with them locked, but if going on the highway i would recommend unlocking them. good luck with your search!
            -Rob
            72 SIII 88
            67 SIIA 109
            82 SIII Stage 1 V8
            • LaneRover
              • 1743
              The locking hubs just 'hook' or 'unhook' the wheels to the drive train. Unlocked the wheels are free to turn which doesn't turn the front differential or front driveshaft. A bit less wear and tear, fewer things spinning and maybe a difference in gas mileage - maybe. A slight headbreeze or having a window open probably negates any gas mileage difference. Also the less wear and tear is also a bit negligible as if you aren't in 4 wheel drive you really aren't spinning anything with much of any force. Little to no Torque is being supplied to the system as it is just the front axle bits spinning away on its own, if it was jacked up you could do it by hand.
              With not much spinning up front you do lose the 'splash' lubrication of the front swivels and you should lock them at least once a month and drive around.
              As siiirhd88 mentions the times he needs to be in 4 wheel drive always seem to be when his hubs are unlocked.
              Brent
              • RoverTrails
                • Sep 2009
                • 12
                Internal part broke in three pieces
                Thank you all for your input!
                I would actually be happy to keep the existing hubs but as you can see from the pic one of the internal parts is in three pieces, it should look like the one on the left. Anyone happen to have one of those laying around? Otherwise, I will checkout the Warn M-11 (thank you rwollschlager). I have emailed Warn should hear something in the next couple of days.
                Thanks!
                • Broadstone
                  • Jan 2009
                  • 216
                  Hope link works? do not know how to do this sort of thing. I had a similar post and the same problem. I have one in good condition and another with the same part in 2 pieces. I gave in and bought new selectro hubs while in U.K. so I have these in the garage. PM if you are interested.
                  1973 NADA 88
                  • crankin
                    • Jul 2008
                    • 696
                    Since the M11 are not made anymore...does warn have another hub that would work? For example the Warn 6094 or 29062?
                    Birmabright Brotherhood
                    Clint Rankin - 1972 SIII SWB
                    • o2batsea
                      • 1199
                      Another vote for no locking hubs. More hassle than they are worth and no significant advantages in gas mileage or drivability.
                      • JimCT
                        • 518
                        Locking hubs
                        I disagree. Used on long highway trips, they save us a noticeable, but small amount of fuel, and less vibration from the front drive shaft and diff, etc. spinning around mindlessly. When I get off the highway, we lock them back in for driving around town. Always locked unless on a long highway trip, but I do think they cut down on wear and tear.
                        1963 Unimog Radio box
                        1995 LWB RR
                        • bkreutz
                          • Apr 2010
                          • 408
                          They also come in handy on parades, low range 1st gear with hubs unlocked. If it tried that on pavement without the hubs I wouldn't be a happy camper.
                          Gale Breitkreutz
                          '03 Disco
                          '47 CJ2A
                          • leafsprung
                            • 1008
                            fwh pros
                            Ive never seen a railco bushing fail from freewheel hub use. Ive disassembled dozens of swivel assemblies and have not noticed a difference between trucks fitted with fwh and those without. Nice thing about FWH is if you have a failure in the front axle (diff or axle breakage) you can disconnect the wheel from the axle and keep driving . . .
                            • bobzinak
                              • Apr 2009
                              • 91
                              Have had hubs on my 2A for almost forty years, never had a problem with the railco bush or any other componant of the front drive system. some times went months without turning them. You gas milage may not see much difference, but for me the big difference was the noise level the front drive train makes with hubs turned. I had selectros ( thee moving parts) for years before finding a pair of warn hubs (many moving parts), that came with a beater that I bought for parts. warns work well, but so did the selectros, nice thing about the selectros, you could turn them easily with a gloved hand. sometimes not so easy with the warns. choose for yourself, but if your a worrier, carry one of the original hub and nuts with you..six in one, half dozen in the other..alot of other things will go wrong before your hubs fall off.. don't get bogged down, rove on my friend..life is short..bobzinak
