I just replaced my SIIa's fluids and started tracking down leaks. I noticed that after the last few drives there is some coolant around the drivers side wheel. It looks like it is coming from the coolant over flow. The truck isnt running hot usually 1/2 to 3/4 at the hottest.
Coolant and oil look clear. The PO put a 15-18 lbs cap in it. I think stock was a little lower.
The head gasket was replaced about 100 miles ago after I replaced a stuck valve.
Should I be concerned or chalk it up to an over filled radiator?
