Early Series IIA Choke Cable
  • SCRover
    • Jan 2010
    • 16
    My Series IIA choke cable is missing the business end (i.e., the handle used to pull it out). I can't seem to find a replacement for either the handle or the entire cable from any of the part houses. Anyone have any ideas? Can I use a newer cable / switch assembly?
    Thanks!!!
  • stomper
    • 889
    I believe you can buy the series III choke cable, and it will fit the IIA. I just bought a universal one from the local parts store, and it works fine. It doesn't hook up to the cold start light though, so I have to remember when it is out.
    • SeriesShorty
      • Sep 2008
      • 275
      For my IIa using a manual choke, I just picked up one from the Help! aisle at my local Auto Zone. $8 and works just fine.
      • SCRover
        • Jan 2010
        • 16
        Cable Update
        Yes...I have a late IIA cable that I'm sure I can make fit....just wanted to try and keep the light also...Thanks for the replies.
        • Terrys
          • May 2007
          • 1382
          Are you talking about the old style choke with the huge mechanical switch on the engine side of the bulkhead ?
          • SCRover
            • Jan 2010
            • 16
            Yep...that's the one...want to try to keep the warning light if I can...though I'll get over it if it's just not plausable.
            • Terrys
              • May 2007
              • 1382
              That's what I thought you had. I salvaged one by pulling the knob, shank and inner cable out of a new generic cable, and hand filling a notch in it where it lets the arm drop in. Took some careful measuring, but it worked, in the end, which all that counts.
              • SCRover
                • Jan 2010
                • 16
                Thanks...I'm gonna look into that option. Thanks again for the help!!
                • leafsprung
                  • 1008
                  email me lemurstew at aol.com
