Anyone with experience in the past know if the 2.25 block heater fits the 2.6 engine? I am guessing it will not, so I'm trying to determine what my options are. As of now my rover is outside and not in the garage because it won't start due to the 20ยบ temp here today.
block heater options for 2.6 engine
I tried again this AM to start Toad, I put a charger on the battery to give it a bit of help. No dice. So I'm probably going to have to buy the generic if I want to get the truck out of the way in my driveway, but before hand I crawled under and looked for the plug. Here is the side with the most plugs in it:
A little research on UK forums last night shows that the threaded plug there is used for the Arctic heater according to this thread on forum.landrovernet.com, but someone there also states it was used for a block pre heater. As this port is found on the 2.25 engine as well, I was curious if anyone knows the size/thread count? No local auto stores here
carry the magnetic or radiator hose heaters so if I have to order something I'd rather get a screw in type._________________________________________
1986 3.5l 110 SW Austrian FeurwehrComment
You can definitely get the truck out of the drive if you have a cast iron frying pan and some charcoal.
Put the charcoal in the pan and light it. Let everything burn til there are only coals and no flames then slide under Rover's engine. Keep an eye on it but leave it for 10-15 minutes or so then start your truck. Works best if there isn't much wind.
If you have a paved drive I would put some wood under the pan.
Or leave a couple work lights with 100 watt incandescent bulbs on in the engine compartment and throw an old blanket over the hood covering the radiator too - this may take a bit longer.1958 107 SW - Sold to a better home
I think I shamed it into starting by putting it on facebook and here, I had to give a turn over a few times and let the battery recover. Still its a temporary solution...
Thanks for the tips though, if it was closer to lunch I might have done it and cooked something at the same time...
EDIT
some more digging and it appears to be 1" BSPT, so I'm not going to find any thread in heater at NAPA methinksLast edited by Cutter; 12-16-2010, 12:48 PM._________________________________________
Ok, I knew those were freeze plugs from my reading, but was mentally focused on the threaded bit. So if I measure that diameter with some calipers I may be able to find one that matches I'm assuming. How does one remove that lovely plug with no discernible edges?_________________________________________
Usually use a drift punch on one side to "turn" the plug, then pull it out with channel locks or something similar.Comment
Phillips & Temro make block heaters for 4 & 6 cylinder rover engines. http://www.zerostart.com/coldStart/e...ck_heaters.asp
part no. 3100070 for 4 cylinder and 3100003 for 6 cylinder. only place on line I could find that had them was www.woodys-auto-supply.com. 2 in stock for the 6cylinderStacy
Motta S.A. ItalyComment
I've always used a long pointed punch. Put a hole slightly off center, and then from the furtherest distance, just used the punch to pry it out. Usually comes out without a fuss. 2.25 is a bit of a pain if the manifolds are on, but still can be done, Your 2.6 looks like you have tons of room.Comment
I wouldn't do a freeze plug heater personally
The things leak and are a pain in the ass to deal with. I would just figure out why it won't start and fix it. They should easily start at 20 degrees. I have had some success in the past with the inline heaters but really a garage is easier.
Let me chime in for lower rad hose heaters. I've had fine luck with block heaters, but better luck (including 4 years in North Dakota!) with rad hose heaters.Comment
