Setting aside the high cost of this I was curious if anyone had use experience with this. I believe our hosts offer it via special order and again it isn't cheap but is purported to worm miracles in terms of improving the noise and vibration levels in the truck. Personally I am good with the noise et al but the charm seems lost on my family.
Description below:
Series Acoustic Moulded Matting System (not V8, Lightwiegt or 6 Cylinder)
This is the only front matting system available that is approved by Land Rover and the Ministry of Defence. This is the Kit. Already fitted to most military Land Rovers and used in extreme environments, this kit has proved itself to be up to the job time and time again. Supplied as a 3 piece kit with the floor & tunnel in one piece with the seat box totally covered and the bulk head centre. Approved at Millbrook testing ground and reduces the noise and heat levels in the front to below required safety standards.
Supplied as a 3 piece kit with the floor & tunnel in one piece with the seat box totally covered and the bulk head centre. The seat box section will require cutting to allow access to the storage sections and gear box access plate. You will also need to clear the holes to suit your vehicles required seat mounting points or any other equipment you may have installed.
Easy to clean
Heat deflective
Water repellent• Extremely hard wearing
Acoustic rubber underside for noise suppression
Drastically reduces noise
Description below:
Easy to clean
Heat deflective
