Cracked head/Block fatigued
  • swray
    • Nov 2007
    • 16
    So, I was starting to really blow coolant out the exhaust, so I pulled off the head and noticed that the old copper head gasket was gone between cylinders 2 and 3. The head was also cracked in this area. The block is not cracked but the metal is discolored and looks kind of fatigued. Would you all try putting a rebuilt head and new gasket in or would you also pull the block out. Sort of running out of funding so was hoping to get away with just the head...
    Steven Wray
    Fishersville, VA
    1965 IIA
    1958 TR3A
  • jac04
    • 1884
    I would thoroughly clean the surface of the block, then check it with a straight edge to be sure it was still flat in that area. If it looks good I would just go with a new gasket and rebuilt head.
    BTW, if you are interested, I have a complete head assembly that came off my Lightweight that the previous owner had professionally rebuilt. PM me if interested and I will dig out the old receipt to see what was done to it.
    • Tim Smith
      • 1504
      My money has it that your block will be fine. Do check it to be sure though. Once you are sure, swap in the new head and gasket and you should be good to go.
      • czenkov
        • Sep 2008
        • 148
        When I pulled the head off mine the gasket was as you described. When I checked the block there was a crack between the middle two cylinders. So when you do the block inspection look closely.
        I ended up finding a rebuilt engine.
        Good luck and I hope yours is fine.
        1960 88" SII Pliny the Elder
        1997 D-90
        "Fear profits man, nothing"
        • swray
          • Nov 2007
          • 16
          Where did you find a rebuilt engine?
          Thanks
          Steven Wray
          Fishersville, VA
          1965 IIA
          1958 TR3A
          • czenkov
            • Sep 2008
            • 148
            Club member had built it, stuck it in his, then found a 2.5 diesel to put in. He pulled the rebuilt motor and I bought it.
            1997 D-90
