Hi Everyone. okay, so here is the problem. when the land rover is really cold and i try to start it with the key, it just doesn't work, like the ignition switch is bad. no click, nothing.. but when i use the push button starter it works every time, no problem.. thats easy enough, as i can just use the push button when the key wont work.. the problem is that once in a while when i turn the key, the started will engage, but will not shut off, i can take the key out all together and the starter will keep cranking until i disconnect the battery.. im worried because i can just picture the starter engaging all on its own and driving the truck out into the road, or worse! ( i park on a slope, and the transmission break is bad enough that i have to leave the truck in gear)
anyone know what might be the cause of this? bad starter solenoid? bad ignition switch?
