OUCH
  • siii8873
    • 1013
    OUCH
    Oh $#!+ pulled a bonehead move. Backed into my wifes car. I want to make some repairs. What is the best way to straighten out crinkled aluminum. Just happens tha about two weeks ago I took a beat tub to the dump. Could use the back galvy piece and back panel now.
    THING 1 - 1973 88 SIII - SOLD
    THING 5 - 1958 109 PU
    THING 6 - 1954 86" HT
  • Terrys
    • May 2007
    • 1382
    At least you didn't break the 4" amber.
    • siii8873
      • 1013
      My thought exactly!! I was glad I didn't damage either the 4" amber or the red one hard to get those.
      • bkreutz
        • Apr 2010
        • 408
        I had similar damage when I got mine. I drilled out the rivets, straightened the steel bits with a regular hammer and dolly but used a piece of wood and plastic hammer on the aluminum so I wouldn't stretch or work harden it. Then rivet back together. Much easier than trying to straighten all the pieces at the same time.
        Gale Breitkreutz
        '03 Disco
        '47 CJ2A
          Well...Replacement bodysides and galv corners are still available. Used 88 tubs are plentiful too.
          • siii8873
            • 1013
            Don't think I'll change the tub. This is my everyday driver and perfection is not a high priority with this truck. I would be interested in a decent straight galv corner if anyone has one.
            • Les Parker
              • May 2006
              • 2020
              Bits and bobs
              Bob,
              I think there's one in the pile in my garage attic. Along with the bare engine block, con-rods and other oddments......
              • crankin
                • Jul 2008
                • 696
                The body sides are available...However, I think the galv corners that accommodate the 4" ambers are tricky to find. I know that I had a time finding one for mine.
                Birmabright Brotherhood
                Clint Rankin - 1972 SIII SWB
                  Fair enough. I was under the (incorrect) impression that the galv corners were universal and that the lamp assemblies all fit the same size holes, but I suppose it's not the holes that are different, but rather the amount of metal around the holes.
                  • JackIIA
                    • Dec 2008
                    • 498
                    This is such a common 'injury' on these trucks. Not sure why, but I've seen it more than a few times.
                    I'd still carefully heat it up before banging away to avoid cracking. Probably unnecessary, but just my own superstitious ways.
                    1970 88 IIA
                    • Terrys
                      • May 2007
                      • 1382
                      You're still kinda right Mark. The outside profile of the early 2A, and S3 are the same. The hole for the lower lamp is in the same position, but the hole for the upper (brake/tail) is up a tad on the late 2A/S3 pieces. Also, the side rivet hole pattern is a little different( Which doesn't matter, because when you redrill the body for the 'other' style, whichever way you're going, the capping covers the old rivet holes in the body.
                      Some light grinding of the upper lamp hole (in galvy and tub)would be necessary to use the old style corner on a newer truck.
                      • mrdoiron
                        • Dec 2009
                        • 446
                        I am looking for a set of the early 2A rear cappings, plus 2 top tub rail caps if anyone can depart with them (for a handsome fee of course). Just PM me if anyone has extra's please.
                        thanks.
                        1961 Ser IIa Hybrid Defender
                        1969 Ser IIa Bugeye
                        1998 Disco - ex wife :-(
                        2010 RR Sport Supercharged
                          Ahh...makes sense.
                          It looks as if one could "adjust" the position of the upper hole to accomodate the larger lower lens and the modification would be hidden by the upper lamp assemblly.
                          • Terrys
                            • May 2007
                            • 1382
                            Ahh...makes sense.
                            Exactly
                            • siii8873
                              • 1013
                              Finished my repairs last week. Came out OK. Pictures attached
