How do I find which transmission is in my series III??
which one?
JACKIIA: Thanks for the photo! What tranny is that mine has what looks like a pickle fork that holds that 1 1/2 inch circular cover in the top cover.Comment
That's a IIA Suffix C box, normally not found in a late IIA (for what it's worth).
I thought the pickle fork you are referring to (fitting on the circular part) was a feature of the early boxes, as in a IIA gearbox, not in a III?? Maybe a III owner can clear that up.
People switch stuff around with these transmissions, surest way to figure out what you've got is to open it up and see about your synchros and layshaft. Hardly worth it unless you are tearing it down because of some problem. (You shouldn't need to know unless you are ordering parts for a rebuild.) Terriann has a good write up on this. Here is the link.
1970 88 IIAComment
JACKIIA: Thanks again! I am getting ready for a rebuild( my reverse is ground down to nothing! I wanted to start researching parts pricing to see if its worth rebuilding or purchasing off another rig. As for the IIa III SWITCH, I know the PO had already switched the tranny in spain while on a trek to africa. So who knows what they replaced it with. I guess I'll have to wait until the tear down. Thanks!Last edited by cousindave; 01-01-2011, 01:30 AM.Comment
I have a SIII full syncro gearbox with the filler cap / flat spring arrangement.
Was told it was a military SIII box, not sure.THING 1 - 1973 88 SIII - SOLD
THING 5 - 1958 109 PU
THING 6 - 1954 86" HTComment
