Yellow Knob/4WD issues.....
  • knac1234
    • Nov 2010
    • 442
    Hello,
    Been meaning to post this for a little while......
    When activating 4wd (hi or lo), I push down the yellow knob and it always works fine.
    When releasing 4wd, I shift the transfer gear into neutral, at which time (I think) the yellow knob should pop up on it's own. It moves up a hair, but I have to pull it up to disengage it. No big deal, but I would be willing to hear solutions on that one.
    What is odd is that sometimes, while driving (I think only in hi but maybe it is happening in lo that I use not often), the yellow knob engages itself into 4wd without me pushing it down. I usually notice this when the steering gets a tad heavy or I notice the lever sitting lower than normal.
    Any ideas?
    Thanks,
    Julian
    Julian
    72 Series III NAS
    03 Disco
    65 MGB / 73 MGBGT
    71 RHD Hillman Super Imp
  • Terrys
    • May 2007
    • 1382
    Is your spring missing, broken, or improperly installed?
    • knac1234
      • Nov 2010
      • 442
      I recall seeing it on the handle, but properly installed is another question.
      That would just affect the release of the 4wd knob, right, or could it also affect the self-engaging issue?
      Thanks Terry...
      Julian
      Julian
      72 Series III NAS
      03 Disco
      65 MGB / 73 MGBGT
      • mrdoiron
        • Dec 2009
        • 446
        Thanks Terry...
        Julian
        Push the transfer fully to low, it should pop up.
        mike
        1961 Ser IIa Hybrid Defender
        1969 Ser IIa Bugeye
        1998 Disco - ex wife :-(
        2010 RR Sport Supercharged
        • jac04
          • 1884
          ... or could it also affect the self-engaging issue?
          Yes, it could. The weight & vibration of the rod would cause it to slowly move down and engage 4WD. Pull up on the yellow knob/rod all the way, if the spring is loose then it should be tightened.
          • lrdukdog
            • 321
            yellow knob
            It's easy to see the spring, just unscrew the y-knob and the spring will be there, should pop-up. If it's there and in good order (not warn out) you can spray with WD-40 and or another spray lubricant all around the area to get it working again.
            Jim Wolf
            • knac1234
              • Nov 2010
              • 442
              Thanks.....will check it out.
              I know the spring is right below the yellow knob. It should be good as the prev owner mentionned replacing it not too long ago.
              Can the spring be tightened/adjusted via the lock nut #19 in the RN link below? There are 2 lock nuts....a top and bottom....do I need to play with both of them?
              That's good to know that if the spring is not tight enough, it could self-engage 4wd with vibration (what vibrations? ). Makes sense that a spring with more tension would help the lever pop up on its own.
              Cheers,
              Julian
              Julian
              72 Series III NAS
              03 Disco
              65 MGB / 73 MGBGT
              • siii8873
                • 1013
                I was doing some maintenance on my SIII and had the tunnel cover off. I found out first hand that the spring is necessary. In my case this was not a smooth engagement it started grinding the gears. It took about a week for it to happen. As someone said the Hi/lo (red knob) shifter needs to be brought all the way to low position to disengage, not just neutral.
                THING 1 - 1973 88 SIII - SOLD
                THING 5 - 1958 109 PU
                THING 6 - 1954 86" HT
                • knac1234
                  • Nov 2010
                  • 442
                  Yes, I had been pulling the red lever all the way down to disengage that 4wd/yellow knob. I am hoping this spring and the nut will allow me to adjust it so it does not require me to manually pull it up.....probably won't get to that til Saturday, but will post any results.
                  Julian
                  Julian
                  72 Series III NAS
                  03 Disco
                  65 MGB / 73 MGBGT
                  • mongoswede
                    • May 2010
                    • 757
                    Julian
                    That's the idea. Healthy setup....never have to pull the knob up....its should pop up when you move the red knob.
                    • Tim Smith
                      • 1504
                      If you are missing the lower spring catch (kind of like a cup for a spring) at the lower end of the spring then it could easily unspool it's self down tunnel hole and leave it's self without enough pressure to release.
                        Exxactly, Tim.
                        Just to clarify Tim's reply, if you disassemble the yellow lever, you should remove the knob, then a nut, then the spring, THEN A SMALL PIECE THAT LOOKS LIKE A FLARED PIECE OF BRAKE TUBING, EXCEPT LARGER.
                        This flared tubing nests in the hole in the transmission hump. The funnel-shaped flare keeps it from falling through the hole. The bottom of the spring rests in the funnel-shaped flare, preventing the spring from working its way down through the hole in the transmission tunel, reducing its effectiveness.
                        Not really shown on the RN online catalog as a separate part, but you can see it at the bottom of the spring in this diagram:
                        • mrdoiron
                          • Dec 2009
                          • 446
                          Originally posted by SafeAirOne
                          Exxactly, Tim.
                          Exactly, it isn't that obvious from their parts pics...in fact when I got my first series, not only was there no spring, but the plate that mounts to the tunnel Mark mentions - that this flared piece rests on, was also not present - so make sure that is also there.
                          1969 Ser IIa Bugeye
                          • knac1234
                            • Nov 2010
                            • 442
                            Fixed!
                            Thanks all for your help!
                            So, I pulled off the yellow knob, and found issue #1-no upper lock nut!
                            Removed the spring, which was visible before, and found no flared spring catch piece....instead there were a few 1/4" washers there! This would have done the job, but, after using a 1/4-28 nut that I had leftover from my Hillman Imp resto, I felt that the spring itself might not be long enough.
                            Not knowing the proper length of the spring from the RN catalog, and not having the flared bit, I added some spacers in between the washers to raise the spring's height closer to the lock nut in order to compress it more.
                            Long story short, it pops up perfectly when moving the red knob to low range, then neutral (I tried pulling up on the yellow knob, and the lever cannot come up any more!). Due to the tension on the spring, I am willing to bet there is no way that lever can now move downwards with vibration to self-engage 4wd (but not yet tested)!
                            So, in addition to no flared bit and no lock nut, I guess when the DPO said he replaced the spring, it was probably with any old one from a hardware store. If I move forward with some light resto work on the Rover in the summer, I will order the right bits then!
                            Now off to try to put that back seat bench in!
                            Cheers,
                            Julian
                            Julian
                            72 Series III NAS
                            03 Disco
                            65 MGB / 73 MGBGT
                            • knac1234
                              • Nov 2010
                              • 442
                              One more question.....is it true that when in lo range, you do not need to push the yellow knob down as it is already in 4wd??? The yellow knob is only for hi range??
                              72 Series III
                              Thanks,
                              Julian
                              Julian
                              72 Series III NAS
                              03 Disco
                              65 MGB / 73 MGBGT
