I have a series III WITH 8.1 unleaded head weber 32/36 dgv with pieerce manifold. Does anyone know what spark plug would be best? Could you also provide the spark plug manufacturers number? Thanks!
sparkplugs
I don't know it off the top of my head, but there have been a few threads on this that list PNs for both 7:1 and 8:1 heads. type "spark plugs" or spark+plugs into the advanced search area (make sure you select technical forums for series I, ii and iii) and you'll find it. Good luck! -
What they recommend and what I use in Mexico
Hi, please see this link:
There you will find what you are looking for.
Besides, the Land Rover Series III parts catalogue dated June 1988 recommends:
RTC 3570 NGK
Suitable for early 8.13:1 and 9.35:1 compression ratio engines.
Equivalent to Champion N12Y.
I use Champion N12Y in Mexico, I do not have many choices, but they are fine, the engine is very strong, starts right up, I have a Weber 32/36 DGAV with Pierce manifold as well. I do not want to hack your thread, so I will start a new one on these carbs.
What mileage are you getting?
Cheers from Tampico, Mexico
Gilberto1969 RHD Lightweight "Gwen"sigpicComment
