Maine Owners
  • Joecarville
    • 11
    Maine Owners
    Are there any Series owners in the 04038 zip code or Greater Portland area?
  • LaneRover
    • 1743
    Though technically my residence is San Diego I spend a lot of time home in Maine when I can. I have a place in Old Orchard and my brother has an old series Rover in N. Yarmouth.
    LaneRover
    • Pete
      • 93
      I am located in Westbrook and know a have a connect with a handful or so guys local.
      Pete
      • TedW
        • 887
        I'm in Falmouth.
        Lots of Series trucks in greater Portland, as I'm sure you know.
        • junkyddog11
          • 195
          I'm in Portsmouth NH and the shop is in Eliot Me. Not to far away and I am in Portland often.
          Matt Browne
          www.overlandengineering.com
          "resurecting junk through engineering"
          • tmckeon88
            • 140
            Maine owners...
            Hi-
            I'm in Biddeford and will be moving to Brunswick this July, but often around the Portland area. I have a green IIA 88" with the Series II and III 4-headlight arrangement and a galvanized nudge bar, in case you spot me on the road some where. Do you have a project in the works? I've done a frame-over rebuild on this vehicle and know a modest amount of stuff -
            Tom
            Tom
            1969 Series IIA 88"
            • cgreen
              • May 2007
              • 2
              LaneRover
              Does your brother happen to live on the North Road?
              • Jeff Aronson
                Moderator
                • 569
                Maine Owners
                I'm well east of you on Vinalhaven.
                I do know that Land Rover Scarborough has a real enthusiast on its service staff in John Read. I recognize Brent, Ted and Tom, too, as helpful enthusiasts.
                Jeff
                Jeff Aronson
                Vinalhaven, ME 04863
                '66 Series II-A SW 88"
                '66 Series II-A HT 88"
                '80 Triumph TR-7 Spider
                '80 Triumph Spitfire
                '66 Corvair Monza Coupe
                • LaneRover
                  • 1743
                  Why yes he does, just over the line from Yarmouth. The jeep and Ford pick-up don't currently run and all he needs for the Rover is the right rear brake cylinder.
                  If you know anyone that needs a Ford pick-up he would probably be intertested in selling it. He stopped using it because there is an oil leak over the manifold that he hasn't taken care of.
                  • cgreen
                    • May 2007
                    • 2
                    Ha--I live just a few houses up the street...I have a disco in the yard and a Series III in the Garage...small world....
                    • Jim-ME
                      • 1379
                      I have a used right rear brake cylinder that just needs a bleeder screw if he is interested. It is in Brewer, ME. Postage shouldn't be that much so I'd be happy to donate it to his project.
                      Jim
                      • LaneRover
                        • 1743
                        Jim
                        He would probably take it to give it a try. With 3 boys saving a bit of cash is always good!
                        "Ha--I live just a few houses up the street...I have a disco in the yard and a Series III in the Garage...small world...."
                        I have been buy a few times, If I remember correctly you have a nice series III.
                        • Tim Smith
                          • 1504
                          I'd of stopped adding oil a long time ago!
