Looking for a USA manual for wiring.
  • Lord Icon
    • Jul 2008
    • 176
    Hi to all. I am looking for info on my series 3 wiring. I oun or have gotten every book I can find and have downloaded the rave info and searched the web. TerriAnn was nice enough to have sent me some info but alas it is too blurry . She mentioned that she had gotten it from a US market manual. Our hosts show nothing for a US market Series 3, I know not why . All info points to the heater as a US spec item , the rest of the world must be tropical. The 4 way flasher and the oil pressure gauge also must be un needed in the entire rest of the world. Forgive my frustration, I thought this whole "inter web " thing was to have information at my fingertips.
    Funny, I can download plans to build a nuke , or a meth lab but US spec wiring for my landy..... no luck.
    Any and all help in the way of useful info I will catalog for others in my boat. May be we can save it as a sticky.
    If anyone knows the trick to the US manual vs the rest of the world, there are many books for sale on e-bay, trouble is , I can't tell if it is the right or wrong one.
    Oh and FYI. The wife bought me the Haynes restoration manual, lots of pics, hardcover ... useless as crap, no wiring at all.
    For sale cheap.
    Whence came you my brother ? From the East....
  • artpeck
    • Dec 2009
    • 368
    I have a US '73 S3 and the green book has not let me down and includes everything i have in the truck with accuracy. I haven't traced every circuit but did go over the diagrams pretty throughly when i got the truck and everything I have had to do so far has been detailed with fidelity. Not sure if there are different versions or editions but happy to share which one I have.
    • Nium
      • Aug 2009
      • 400
      Wiring Diagrams for Series III
      (The above links web site http://www.landroverweb.com/landrove...rover-manuals/ )
      At least if you already have looked at all those links you can tell us hey I already looked at all those links
      Walker
      1968 Series IIA-"Ronnie"
      88" SW, 2.25L Petrol, LHD
      • Lord Icon
        • Jul 2008
        • 176
        Been there done that
        Yes, I have looked at those already,
        The first is from our hosts, great at parts , poor at US spec wiring.
        The second and third are british and military british.
        Tell me more about this green book you speak of........
        • jac04
          • 1884
          Green book = factory service manual. It should really be one of your first purchases after becoming a Rover owner.
          • ignotus
            • Sep 2009
            • 237
            wiring
            I own a factory repair manual from when I bought my 73 88 in 1974. It is a gray 4 ring binder for mechanics. It does not show any wiring schematic for a series 3 heater.
            It does have a section on heating and cooling. in the Heater fan switch section it lists the brown/orange tracer going to the upper right proturding part of the back of the switch. Below that connects the green/yellow tracer, below that a green/slate tracer.
            Under the blower fan motor section it just shows 2 leads going to the motor, "brown lead with green marker band---to green/slate lead, green lead-- to gree/yellow lead."
            I no longer have the 73 so I can't go look. Hope this helps.
            gene
            1960 "bitsa" 88--Ignotus
            1960 109, 200TDI
            • artpeck
              • Dec 2009
              • 368
              I just looked at my repair operation manual and indeed it does not include either the oil pressure gauge or (less obviously) the warning flashers in the wiring diagram. Happy to look at mine if that would help on specific questions.
              • ignotus
                • Sep 2009
                • 237
                flasher system
                coming off the #6 side of the fuse with a green wire to the flasher switch. from the flasher switch to the direction indicator switch with a light green/brown tracer wire.
                2 wires comming off the direction indicator switch 1 is Green/white goes to both RH lamps and to warning lamp indicator RN black/red to ground. 1 is green/red goes to both LH lamps and to LH warning light indicator(dash light)
                I can find no reference to the red pull switch located on the facia support or the flasher unit associated with it.
                gene
                1960 109, 200TDI
                • ignotus
                  • Sep 2009
                  • 237
                  oil pressure
                  the oil pressure was orginally a switch controling a warning light not a guage. It came off the #7 side of the fuse in a white wire down to the warning lamp then out in a white/brown to the pressure switch from thence to ground, probably black.
                  gene
                  1960 109, 200TDI
                  • lrdukdog
                    • 321
                    manuals
                    These might help.
                    Jim Wolf
                    • Terrys
                      • May 2007
                      • 1382
                      The thread is a virtual repeat of one a few months ago. Neither the Green Bible, nor the Haynes Manual, nor the Rovers North website (and old hard copy series book so sought after) reflect the US S3 wiring, with respect to Heater Blower, Oil pressure Gauge, or Hazard Warning Switch, and flasher (seperate from turn signal flasher)
                      I posted the correct US Spec schematic in that thread.
                      Last edited by Terrys; 01-19-2011, 07:53 AM. Reason: to include link to old thread
