shifting a series IIa
  • woodman1
    • May 2010
    • 37
    I have a 63 series IIa. How does one get from 1st to second or third to second without grinding gears? Any advice is appreciated.
  • jac04
    • 1884
    You need to double-clutch.
    If you are traveling in 1st gear, and want to shift to 2nd:
    Depress clutch pedal
    shift to neutral
    release clutch pedal
    depress clutch pedal
    shift to 2nd
    Same for 3rd to 2nd, or 2nd to 1st.
    • rbbailey
      • Sep 2010
      • 161
      I've never had trouble going from 1 - 2.
      But even after years of driving, I still can't get it to go from 3 - 2 properly, unless I'm at or below 5 mph... which I don't know if that is normal.
      • Jim-ME
        • 1379
        When downshifting blip the gas pedal when in neutral with the clutch engaged.
        jim
        • rbbailey
          • Sep 2010
          • 161
          jim
          Small blip, big blip, medium blip, no blip, blip with double clutch, 3rd blip clutch down to 2nd, blip with double clutch bump to 3rd then to 2nd, no blip bump to 3rd down to second, double clutch then blip then to 2nd, blip after double clutch from 4th, bump to 3rd, revs down, then blip, big blip, small blip....
          Grinds a bit every time, never slides in unless I'm nearly at a crawl.
          Like I said, it goes from 1st to 2nd very cleanly. And going into first after a bump to 3rd is nice and clean.
            • 499
            this question is a joke right? It is so commendable having a 'enthusiast' being a Land Rover fan but what's this about figuring how to shift?,, even a worn out full syncro?????????????????????????
            • LaneRover
              • 1743
              If all you have ever driven is full syncro boxes then one without a syncro can present a small learning curve.
              Personally I have never double clutched. I just wait a moment. Most of the time from 1st to 2nd I don't even use the clutch. Just as I am coming off the throttle I pull it out of 1st, I wait a moment and then put it into 2nd. It takes a bit of learning the timing but once you get the timing down it is really easy.
              But even when using the clutch, I just wait a moment before putting it into 2nd.
              • Burlsube
                • Jul 2010
                • 62
                Good luck... A few months ago I asked a similar question. Search for a thread called "downshifting" It was an animated discussion. The folks at GnR got a kick out of it. We all need to start somewhere though.
                • rbbailey
                  • Sep 2010
                  • 161
                  Well, I should qualify my post -- I've owned this truck twice. The first time I owned it, I don't remember having this issue once I figured out the double clutch thing. Not to say that I never missed it, but I don't remember it grinding more than say... 20% of the times I downshifted.
                  So this is why I'm confused about why I can't seem to get it right now.
                    I haven't posted on GnR for a while now. The atmosphere there just wasn't the same since it moved. Don't get me wrong, theres lots of good people there, most are here as well. I'm alright with redundant questions or what I would consider easy questions. If I'm not interested I just don't read them, it's that simple.
                    As far as shifting a IIa tranny...lots of practice.....and sometime you still miss a gear!
                    • JackIIA
                      • Dec 2008
                      • 498
                      I was taught to ALWAYS hit the gas between (and out of gears), not just when downshifting to double clutch.
                      Which is it and why.
                      (I had assumed it was to give the flywheel side of things an assist when engaging the next gear).
                      1970 88 IIA
                      • Donnie
                        • 287
                        Jack, on this trans. when you shift a gear, the gear on the mainshaft must slide onto the countershaft gear.. the countershaft gears do not move..So the idea is to get the speed of both gears turning about the same speed & they will slide together. practice the intensity of your "blips".....vehicle speed in involved in this process too. only the mainshaft gears slide, the countershaft gears spin only and do not move fore & aft.......when U let the clutch out in neutral in this manuver & blip the throttle U R speeding up the countershaft and the speed of the mainshaft is being determined by the rear wheel or vehicle speed...PRACTICE until U get both equal..HTH........donnie
                        • JackIIA
                          • Dec 2008
                          • 498
                          OK, getting a visual now Donnie, thanks. I'm assuming by countershaft you're talking layshaft.
                          1970 88 IIA
                          • Alaskan Rover
                            • Apr 2010
                            • 54
                            shift to neutral
                            shift to 2nd
                            LOL...I've driven my series IIA for 24 years now and who knows how many thousands of miles and have NEVER double-clutched it going from 1st to 2nd, and it is a standard non-synchro IIA tranny just like all the other series IIAs. That just shows you how incredibly strong rover trannys and clutches are, I suppose. I'm knocking on wood as I write these words, of course, lest I jinx my transmission.
                            1970 Series IIA 88".,...the REAL Chitty Chitty Bang Bang.
                            • JimCT
                              • 518
                              Why not?
                              Why don't you double clutch? It is a straight cut 1st and 2nd gear?
                              1963 Unimog Radio box
                              1995 LWB RR
