Started work on Gearbox swap..
  • rejeep
    • Apr 2010
    • 420
    Got this in the mail the other day..
    well not exactly the mail, but you get the point..
    Series 3 recon gearbox suff D.. from Ashcroft..
    Seatbox Removed.. came out fairly easy, only 2 bolts were stuborn.
    Enough Room to work now....
    1971 SIIa 88" NAS Dauntles V6
    1974 SIII 109" RHD
  • cousindave
    • Jan 2007
    • 192
    Ahhh land rover ****!
    • gudjeon
      • 613
      That new transmission is a thing of beauty.
      • rejeep
        • Apr 2010
        • 420
        seemed like I needed it too more than I thought..
        there was a tooth in the gear oil that was drained..
        it was really something special to unwrap I must say..
        Since it is brand spanking new.. I am debating what to fill it with..
        I ran Mt90 in my old box until it started leaking uncontrollably.
        Im wondering if I just use regular old 75-90
        1974 SIII 109" RHD
        • bkreutz
          • Apr 2010
          • 408
          I use 75/140, seems to cover all the bases for me.
          Gale Breitkreutz
          '03 Disco
          '47 CJ2A
          • Tim Smith
            • 1504
            You will find it a bit easier to do the swap if you remove the roverdrive before pulling the old trans/t-case out and putting it back on after the new one is in place. The clearance on the back of the roverdrive and the frame can get a bit tight as you're aligning the input shaft to the clutch plate. However, if you forget, it is still possible to squeeze in with the roverdrive on. Just be careful not to bend the clutch plate.
            Have fun!
            • rejeep
              • Apr 2010
              • 420
              yes.. roverdrive was pulled before and will be installed after...
              1974 SIII 109" RHD
              • westcoastkevin
                • Jan 2011
                • 162
                What OD unit do you have?
                Edit: DUH, roverdrive.
                • yorker
                  • 1635
                  If it is brand new it shouldn't leak, I'd fill it with Stalube GL4 and run it for a while, then change that out for whatever manual transmission lube you prefer.
                  http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1137238#Post113 7238
                  White Paper - Synchromesh Manual Transmission Lubricants Since there has been so much discussion and questions about MTL's, here is a white paper that I hope answers some questions. Quote: Most GL5 differential and GL4 Manual Transmission oils contain sulfur-phosphorous EP packages. GL4...
                  Land Rover UK Forums
