I completed my crank / crank bearing rehab on the 2.25 petrol. All the work was with the crank I did nothing with the camshaft.
Before I closed up the oil sump I put the #1 cyl at TDC with the "P" on the camshaft orientated per the green bible. Assembled the timing chain assembly maintaining this orientation with the drive side of the timing chain tight. Was going to install the distributor so checked the orientation of the dizzy drive gear. It is off by ~90deg from where the book says it should be. I rotated the crank / camshaft and watched the valves.
I placed a plug in the #1 cyl only so I could also feel the cyl compression. All looked correct, the exhaust valve opened,closed, the intake valve opened, then closed, the cyl started compessing and the pointer came around to TDC. The "P" was right where it should be but the dizzy drive gear is off as noted. What am I missing?
BTW the camshaft was replaced by the PO with a performance cam if that makes any difference. Pictures attached.
