Free Wheeling Hub Removal
  • Paul and Judson
    • Sep 2010
    • 110
    Our Series III has free wheeling hubs on it. If I want to remove them, how would I do it and what parts do I need to purchase to replace the hubs.
  • yorker
    • 1635
    Which hubs do you have? Warn? Superwinch? AVM? there are like 20 different ones out there. What is wrong with them? If you want to replace them you need new lock out hubs or drive flanges (look at your rear axles).
    Land Rover UK Forums
    • Paul and Judson
      • Sep 2010
      • 110
      I have Dual-Matic Hubs which leak a great deal. I know I can rebuild them but I do not drive my Rover very much and the gas savings from having the hubs installed hardly seems worth having the trouble of a rebuild or having to clean newly painted wheels.
      Thanks for the feedback
      • siii8873
        • 1013
        Paul,
        when you get rid of the lock out hubs the hub assembly on the front will be the same as the rear. You need to get the drive flanges, caps, gaskets. If you have a spare rear axle you can get the parts from there.
        Just note how the come off that axle and reverse this for assembling on the front.
        THING 1 - 1973 88 SIII - SOLD
        THING 5 - 1958 109 PU
        THING 6 - 1954 86" HT
        • Paul and Judson
          • Sep 2010
          • 110
          Bob,
          Thanks. I appreciate the helpful information.
          • jac04
            • 1884
            You may also need new drive flange bolts. Some lock-out hubs use longer bolts, so when you switch back you will need the original shorter bolts. IIRC, the Dual-Matics take the longer bolts.
            • Jeff Aronson
              Moderator
              • 569
              What JAC and Paul said above. I removed my worn-out Warn hubs by calling RN and asking for "all the parts I need." The job was easy, even for me, with my only hesitation being the torque used on the big hub nut and the castle nut.
              In the end, you'll be running the car in the "locked" position by definition. Over the long haul, you'll probably lubricate the innards of the front wheel drive components inside the swivel balls better because the lubricant is splashing around all the time.
              Jeff
              Jeff Aronson
              Vinalhaven, ME 04863
              '66 Series II-A SW 88"
              '66 Series II-A HT 88"
              '80 Triumph TR-7 Spider
              '80 Triumph Spitfire
              '66 Corvair Monza Coupe
              • siii8873
                • 1013
                Jeff,
                you make a good point here about lubricating the swivels. I make it a point to engage my hubs on a regular basis to insure that the gear oil is getting sloshed around in there and lubeing everything up. I do this even more in the winter to hopefully ward of swivel ball corrosion from salt also.
                • Momo
                  • 347
                  Also be very careful when unbolting the Dualmatics. I would heat the bolt heads gently with a propane torch, allow to cool a bit, and then spray with penetrating lubricant (PB Blaster works great). It will work in there as everything cools and make life easier... the goal being to prevent those long bolts from snapping off inside the wheel hub. Very frustrating!
                  Once the Dualmatics are off, this is a good time to renew the wheel hub oil seals and roller bearings. These parts can be found at most good auto parts stores if you use the cross-reference list located here: http://www.ovlr.org/OVLR.alt.parts.html#bearings
                  '60 SII Station Wagon
                  '64 SIIA 109 Regular
                  '68 SIIA 88 Station Wagon
                  • singingcamel
                    • 398
                    You know ,while your doing all this ,I would have a quick peek at the conditions of the axles , looking for twisting and wear..
                    www.singingcamel.com
                    • I Leak Oil
                      • 1796
                      ...and since the hubs, spindles and axles are out you may as well rebuild the swivels and remove the diff to check it out also.....
                      Oooo....shipfitters is setting in....
                      • Mountain132
                        • 79
                        then while you're at it change your brakes and springs
                        and wheel cylinders
                        and flex hoses
                        and have your drums turned
                        and....
                        ....then handle breaks off and you need the Dr. to pull it out again (Wayne's World)
