WANTED: Pics of Inertia Seatbelts
  • NC Rover
    • Dec 2007
    • 288
    Looking for some pictures of anyone with inertia shoulder belts in their Series rovers. Mainly looking for pictures of the attachment points where the belts are mounted.
    thanks!
    NIck
  • jac04
    • 1884
    Hard top or soft top?
    • ducttape
      • 169
      Soft top
      I am adding a soft top to my truck (from it's current hard) and need to figure out belting too.
      I'd like to be able to switch back and forth, although I don't know how much I will end up doing that.
      1967 Series IIA 88
      • Cutter
        • Feb 2009
        • 455
        I'll take some pics, I just properly installed the set in mine, though my 109 has a hard top so no help on the shoulder bracket. At some point I'd like to fabricate or buy a bar that will mount them so I can run without the top.
        • rejeep
          • Apr 2010
          • 420
          i instaled defender ones in my 109 SW..
          I can prob grab pics tomorrow when I get up to the shop..
          they were a lot simpler to install than I thought they would be.
          1971 SIIa 88" NAS Dauntles V6
          1974 SIII 109" RHD
          • Les Parker
            • May 2006
            • 2020
            Soft top seat belts.
            Here's a copy of the Defender 90/110 seat belts that I fitted to the Airportable some time ago :-
            Hope this helps, please note you have to remove this when fitting truck cab or hard top roofs !
            • tuko
              • 22
              thanks!
              NIck
              Here is my setup on my series 3:
              Todd.
              My Series 3 Hybrid
              300Di Powered
              Småland Traxx - Offroad Aventure Tours. More info can be found on Facebook.
              • Cutter
                • Feb 2009
                • 455
                here's the reel mount on my 109 p-up. the bracket shown is mounted to a lower bracket under the seat box that attaches to the frame outrigger. For a long while mine was just attached to sheet metal which didn't provide much protection. Sorry its not the best photo, tight quarters back there.
