bulkhead & frame weights
  • stonefox
    • Jul 2010
    • 450
    Anybody know how much a striped bulkhead and 88 frame weighs?
    Sean
    1963 88'' IIa daily driver
    1970 88"
    1971 88"
    authenticstoneworks.com
  • mongoswede
    • May 2010
    • 757
    stripped or striped A bare bulkhead with fresh paint like the one sitting in my living room weighs less than 100 lbs. I can pick it up and carry it myself so I am pretty sure its in the 50 to 75 lb range.
    • albersj51
      • May 2010
      • 687
      I was told the frame weighs approx 750lbs
      • Terrys
        • May 2007
        • 1382
        I don't think that's right. Two people can carry one.
        • albersj51
          • May 2010
          • 687
          I want to say I heard it from someone at RN, so I may very well be wrong. I've got to pull mine next weekend, so I hope I am.
          • solihull109
            • May 2007
            • 191
            A stock frame, no way. Agreed, two guys can carry it. A galvanized frame is heavier, but again we move them with two guys.
            knowledge without experience is just information.... Mark Twain
            www.downeastcoachworks.com
            • mongoswede
              • May 2010
              • 757
              I can slide a stock frame by myself and I can flip one over sideways with some effort. I'd guess they weigh between 300 and 500 lbs as two of us have picked one up before without really struggling too much. The galvanizing could add another 50 lbs or more to the weight.
              • leafsprung
                • 1008
                I can carry a frame by myself, must weigh something like 85-90 lbs.
                • JackIIA
                  • Dec 2008
                  • 498
                  Agreed. No way does the frame weigh over 125lbs. The biggest problem is it's awkward. But I've moved mine around plenty of times on my own. I do recommend a helper (or an engine hoist) to get it in place on the frame.
                  1970 88 IIA
                  • albersj51
                    • May 2010
                    • 687
                    I am apparently WAY off base here! Thanks for the correction (and the confidence)! Now I can get my friends son and friend to yank the old frame while I drink a guinness and "supervise"
                    • Terrys
                      • May 2007
                      • 1382
                      Do I remember seeing you on a Wheaties box?
                        Rusty frames don't count Ike....
                        • mongoswede
                          • May 2010
                          • 757
                          125lbs sounds a little optimistic.
                          • stonefox
                            • Jul 2010
                            • 450
                            I appreciate you guys narrowing it down for me to some rough numbers of between 85-750 lbs
                            Were I was going with this was trying to get an idea of how much it was going to cost to have them galvanized.I was told it was based on weight .Can you fellas give me a rough idea what it may cost for frame ,bulkhead,breakfast ,and other assorted bits.
                            If there is any thoughts on preping such as bracing or "I wish I had" you want to share Or If this has all been cover maybe point me to a link.
                            Cheers
                            Sean
                            1970 88"
                            1971 88"
                            • bpj911
                              • May 2009
                              • 128
                              frame
                              Based on what I have seen posted previously I recall it being around 350 pounds.
