Spare tire mount
  • JimCT
    • 518
    Spare tire mount
    Just curious, has anyone seen a spare bracket like this one on our 1968 Marshall ambulance?
    1963 Unimog Radio box
    1995 LWB RR
  • Tim Smith
    • 1504
    Do you actually need it? My hood tire mount has been without that the whole time it's been in the family and holds the spare just fine.
    By the way, good job on keeping those threads lubed up!
    • Clive
      • 79
      It looks like the standard station wagon rear door spare tire mount - just put on the dished hood. I have seen them used on the hood like this before. It is missing the "U" part though.
      • galen216
        • 236
        x2 on the door mount.
        When I got my truck the PO had used the rear door mount on the hood and it looked just like that.
        74 SIII
        96 Disco SE-7 5 Spd.
        • Tim Smith
          • 1504
          Just reread my post and realized that it wasn't clear. I was asking if the ring was needed. My military uses the same 3 bolt tire holder on it's hood but has been without the ring for as long as I know of.
          Cheers,
          • JimCT
            • 518
            rear door mount
            The rear door mount has a much smaller base plate.
            1995 LWB RR
            • Clive
              • 79
              Base plate is definitely biggger...doubt you really need the bolt-down plate but it will make it a firmer fit. Nuts alone would hold it.
              • jp-
                • 981
                It may be a better hold down, but it looks awful compared to the civilian type.
                67 IIA 109" NADA Wagon (sold)
                • luckyjoe
                  • 335
                  Military parts
                  That is a LR military, bonnet-mounted spare holder. All the Marshall ambulances had them. Very robust mount, and a 7.50x16 tire is positioned up/off the bonnet - hence the large base plate to distribute the load to the bonnet frame. It is complete as pictured , and does not use the "U" found on the rear door tire mount.
                  It doesn't really matter much what it *looks* like, as it holds the spare tire (which is what you'll actually see). That said, with the spare tire removed, it definitely doesn't look "civilian"...
                  Regards,
                  Tom P.
                  Tom P.
                  1965 exMoD 109
                  1995 RRC LWB w/EAS
                  • Momo
                    • 347
                    Tyre Mount
                    Ditto what Luckyjoe said. Also, that is genuine ex-MoD crud in the tire dish. I consulted my military Land Rover manual, and I quote:
                    SECTION XIIII
                    HOLDER, CRUD, FIELD AMBULANCE.
                    In accordance with article 14 of Her Majesty's Field Ambulance Corps specification guide, all said vehicles shall maintain a repository of crud no less than 1/8 imperial inches deep. Said crud shall consist of peat moss, bogwater slurry, or an acceptable substitute of western European muck (Rhineland paddock goop, Polish swamp ooze, Czech forest dung, etc.) Really anything you squaddies can scrape up in the event of war with the Ruskies.
                    Please refer to section XXII of this manual for the following applications:
                    1. As aWound poultice;
                    2. As a skin camouflage application;
                    3. For oil leak plugging;
                    4. For smearing on windscreen to shield occupants from low-yield atomic weaponry;
                    5. As a flavoring for afternoon tea.
                    THIS SECTION TO SUPERCEDE SECTION XI OF MANUAL, FIELD AMBULANCE, 1955. REMAINING LOWER THIRD OF THIS PAGE INTENTIONALLY LEFT BLANK TO CONFUSE EAST GERMAN SABOTEURS.
                    '60 SII Station Wagon
                    '64 SIIA 109 Regular
                    '68 SIIA 88 Station Wagon
                      • 383
                      This was the same spare mount that was on the wife's wrecked SIIA ex-amby 109. It is certainly much more substantial than the standard pieplate mount, and was on a deluxe dished bonnet that used the two hold down spring hooks and no latch to the breakfast. I ended up replacing the bonnet due to damage and used a deluxe dished bonnet with a normal latch, and will add the two hold downs later. I still need to swap out the bonnet with the deluxe non dished bonnet on my 109, due to her much larger sized spare tire blocking too much view.
                      '96 Disco SE7
                      '80 SIII 109
                      '75 SIII 88 V8
                      '66 SIIA 109 V8
                      '6? SIIA 109 pickup
                      • JimCT
                        • 518
                        Official gunk
                        And they were not shy at all applying paint....
                        1995 LWB RR
                        • Leslie
                          • 613
                          SECTION XIIII
                          -L
                          '72 SIII SW 88"
                          '60 SII 88" RHD
