IIA running rough at idle
  • tmckeon88
    • 142
    I have a 1969 IIA 88 with the usual 2.25L gas engine and a Weber single barrel carb and just in the last couple of days it has started running really roughly at idle, such that it will stall at a stop sign. It runs and drives and starts OK otherwise, but I find I have to keep the choke part way open to keep it idling. It has always had a good idle in the past. It's been cold here in MA but it has been running fine all winter. Should I be looking at the points? A vacuum leak? Clogged carb jet? I did a full tune up last spring.
    Any ideas from the more experienced than I would be very welcome.
    Tom
    Tom
    1969 Series IIA 88"
  • Terrys
    • May 2007
    • 1382
    Tom, any of the other things you mentioned can be a source of idle problems; points being the most likely of the others, but It's been my experience that the Weber has a very fussy idle circuit. Clean fuel is a must also. I'd pull the idle mixture screw out, blow out the jets, reset the idle mixture and check that the bowl is clean.
    • tmckeon88
      • 142
      OK, I'll try those things. I might get a new rubber elbow for the vacuum line too, and I might as well order tune up parts with the gift certificate I got for Christmas. I just need some milder weather to do all this since I have to work outside!
      Thanks,
      Tom
      Tom
      1969 Series IIA 88"
      • singingcamel
        • 398
        Theres alot of issues that can cause a rough idle.. I would check the low tension leads, make sure there seated tightly on the plug, vaccum leaks are a real stinker. check for leaks ,bad hoses. retorque you carb at the base . check dizzy cap and rotor for wear and corrosion. readjust the carb.
        Whens the last time you adjusted the valves..
