rear main seal question...
  • masonater
    • Nov 2007
    • 329
    I have the old one out and T seals out as well, i found a stash in the hangar of all types of silicone, hi temp RTV silicone, aviation form-a-gastet, regular form-a-gasket, ect...what would be a good one to use? if any...I ask because i've heard there are some you absolutely do not want to use. The metal surfaces all look nice and clean. I noticed the old seal was banged up a little bit on 2 different spots, i guess thats why it was leaking...
    Thanks, Mason
    1970 Series IIA 109 EX-MOD
    1971 Series IIA 109 EX-MOD
    1982 Mercedes 300TD
    1989 RRC
    1993 D110
    1994 RRC LWB
    1995 RRC LWB
    1995 RRC LWB
    1995 Disco
    1996 GMC 2500 Suburban
    1996 Disco
    1997 Disco
    2001 RR P38
    2005 LR3 HSE
    2006 RR HSE
  • rwollschlager
    • Sep 2007
    • 583
    IIRC the green bible calls calls specifically for hylomar which is (according to a quick google search) " this non-chlorinated gasket and sealing compound has been specially formulated to be non-setting and non-hardening at elevated temperatures. Even at these high temperatures, Universal Blue Racing Formula remains flexible and tacky, allowing repeated disassembly and reassembly in high performance applications."
    So if anything on your shelf that fits that guideline it should work fine, otherwise RN sells the original stuff: http://www.roversnorth.com/store/p-5...00gm-tube.aspx
    -Rob
    72 SIII 88
    67 SIIA 109
    82 SIII Stage 1 V8
