I'm wondering if anyone knows the sizes for the male/male adapter that screws into the block, then you screw the water temperature sensor into that? It's part # 568457. I was just wondering if anyone knew the thread sizes to see if I could source something locally.
Oil temp/Water pressure fitting
The male to male adapter that fits a female fitting at the sensor bulb of a Smiths mechanical temp gauge on one end and and screws into a threaded engine hole at the other end.
I could use one of those as well. Anyone know a source for these male to male adapters??-
I'm pretty sure of two things: It looks like this, but this isn't it. I think I have a few, and if it get's above 10 degrees, might be able to go upstairs in the barn for a look for the right ones. I'll need to find a butterfly gage to check it against too.
I have a 10' piece of hex brass and can set up the Gallicop to make a bunch, but it'll have to wait till sugaring is over.Comment
568457 is a male / female adapter used to install the electric water temp sending unit (560794) into the head. It is used with sealing washer 243959.
568457 should be readily available for $10. I bought one not too long ago (from Bill at tntlr.com): http://www.tntlr.com/content/adapter-wtemp-impComment
Terry, that is exactly what I'm looking for. Lemme know if you find any in your search.1956 86" S1
1957 88" S1
1967 109" SIIA NADA
2007 LR3Comment
For reference, the correct part numbers are:
218512 Union for thermometer bulb, Petrol models
243959 Joint washer, union to cylinder head, Petrol modelsComment
Adapter
Greetings Utah & Terri...... Just spoke with Les here and he happens to have two of those adaptors left in his stash... Give him a call.Comment
Adaptor
I had some of these machined a few years back.
I have 2 of them left @ $20.00 each.
Let me know.Les Parker
