Just picked up a 78 109" today from the port. With everything in neutral, it will not roll freely. Seems to be the front wheels. When in gear, it is hard to get it to go forward or reverse and there are tread marks on the drive. Could the front brakes be locked up? This is the oldest model I have had. Does "free wheeling hubs" have anything to do with it? Thanks in advance for your response
Won't Roll
Won't Roll
sigpic
Nate B
88 D90 RHD, V8 Present
80 Merc 230GE Petrol in 2011
92 Range Rover - In the 90's
has it been sitting?
If its been sitting its probably brake drag. If its not been sitting it could still be brake drag, but probably for different reasons. I am, assuming you are just pushing it by hand?1968 Land Rover "Park Ranger" camper **SOLD**
1967 109 **SOLD**
NADA Dormobile #601 **SOLD**
1965 IIA 88 2.5NA Diesel
1963 Mercedes 300se
1975 Volvo C303
KJ6AQK -
if in neutral, should the front and back wheels turn by hand if both suspended off the ground? Asking so I know which brakes to look at first. Also, is it possible to disable the parking break?sigpic
Nate B
cuis2000@yahoo.comComment
In Neutral the wheels should spin by hand. If the parking brake is stuck on you could put the transfer case in neutral and the front wheels should then be able to spin. That would tell you if the parking brake is the culprit.
If you think it is the brakes at the wheels then one option is to use something to pull the rover and give each rim a sharp rap with a hammer. The bigger the better and not so hard that you are bending things but a sharp rap to hopefully break the rust or whatever is holding your brakes solid.1958 107 SW - Sold to a better home
Seemed to brake freeze with the fronts. Pulled the drums, cleaned with brake cleaner and they turn by hand. Not as easy as the rears though. Thanks for your helpsigpic
Nate B
This happened to me. Rolled fine, but then after sitting for a couple months, front wheel was stuck. I loosened the brake shoe adjustment screw and that let the wheel spin freely.Comment
I see you've put this up on eBay.rikuwoiku — to travel overland.
2002 Discovery II SE
SeriesParts.com — A master list of parts, part suppliers (our gracious hosts included), and repair shops for Series Land Rovers.Comment
