Gearbox indentificaton
  • JimCT
    • 518
    Just picked up 2 gearboxes today, on 15101218 no letter and the rubber fill cap held down with an arm, the other is 25470182 F. Could anyone help with what years these would be? thanks Jim
    1963 Unimog Radio box
    1995 LWB RR
  • cedryck
    • Sep 2010
    • 836
    Jim, knowing if they have sycro's in second gear would help ID the 2a to series three years.
      You know Jim, there was so much overlap in parts and years that I think it might be imposible to determine an exact year with any certainty. The best you can hope for is to figure out if it's a synchro or non-synchro box and that might give you a period of time when they were used. Example, if the F suffix box is non-synchro then it's most likely a much later SIIa, probably '70 or '71. Not sure the SIII boxes ever made it to a suffix F or not. The box with no suff. letter is obviously an early unit, synchro or non? Does it have holes on both sides of the bell housing for the clutch linkage?
      • JimCT
        • 518
        bellhousing
        The older one does have holes on both sides of the bellhousing. If I am correct that should have the lower geared transfer case. Thought that might work well with the newer gearbox and give the ambulance a bit more grunt in the woods.
        1995 LWB RR
          Ooooo.....that's a good piece for someone. Probably an early SII. Makes a good retrofit for SI's because of the bellhousing. Not sure of the gearing, but if you keep the transfer case then offer the tranny out so someone can keep an early series going! NICE!
          • yorker
            • 1635
            I think ther F was the latest of the IIa's so it should have all the IIa upgrades. as for the other t case:
            Land Rover UK Forums
