Free to good home/Needs Rebuilt 2.25 Engine
  • SGS714
    • Jan 2007
    • 83
    We are almost done with the new engine install and ready to either send this to the scap yard or give it to someone that can use it. Complete long block with Rochester Carb.
    The #2 cylinder has 20lbs of pressure...Everything looks good under the valve cover and assume it is either a valve or piston issue.
    Located in Decatur IL. Not looking to deal with alot of shipping logistics, but can have it ready and loadeded with a days notice.
    ________________________
    67 Series II
    93 D110 NAS 327
    94 2x D90 NAS #'s 1076, 1181
    95 3x RRC 2-SWB, 1-LWB
  • bmohan55
    • Sep 2008
    • 435
    pm'ed ya
    '72 S3 88 - Leakey & Squeaky
    • SGS714
      • Jan 2007
      • 83
      I have had a couple of folks that want the carb....I will wait at least a week or so before I part that out. I really want to help someone somewhere and keep this block from going to the junk yard.
      67 Series II
      93 D110 NAS 327
      • albersj51
        • May 2010
        • 687
        does it include the head? If so, is it a 7:1 or an 8:1?
        • SGS714
          • Jan 2007
          • 83
          Yes-Includes head. My assumption is it is a 8:1 but do not know for sure. Anything I can look at that tells me?
          67 Series II
          93 D110 NAS 327
          • albersj51
            • May 2010
            • 687
            From TAW's website (too lazy to type it myself).
            QUESTION - How can I tell if my 2-1/4L petrol engine has 7:1 or 8:1 compression? If I have a 7:1 head can I mill it to make an 8:1 head?
            ANSWER - Look at the center head bolt between the carburetor and the valve cover. The surface of the head under that bolt may look like the other head bolt mounting surfaces or it may be a raised flat surface about 2.5 cm (1 inch) wide that goes between the valve cover and the edge of the head.
            If the mounting surface under this head bolt looks like the surface under the other head bolts, you have an earlyish 7:1 head.
            If you have the raised rectangular surface look carefully to see if there is a number stamped on that surface. If there is no number or a 7 stamped there then you have a late 7:1 head.
            If there is an 8 stamped there (Mine looked like two zeros that were stamped to make an 8) then you have an 8:1 head.
            Only heads with the raised flat surface that have an 8 stamped on it are factory 8:1 heads.
            • My wife said no landy!
              • Feb 2011
              • 12
              Wish you were closer.
              • SGS714
                • Jan 2007
                • 83
                Raised area with nothing stamped on it.....Thus this is a late 7:1 head.
                67 Series II
                93 D110 NAS 327
                • siii8873
                  • 1013
                  The stamped 8 is not always there. I have a head which was purchased from RN by PO (have receipts) that is 8:1 and not stamped.
                  THING 1 - 1973 88 SIII - SOLD
                  THING 5 - 1958 109 PU
                  THING 6 - 1954 86" HT
                  • SGS714
                    • Jan 2007
                    • 83
                    I tend to think 2 owners back did upgrade to 8:1 but do not know for sure thus I am representing head as a 7:1....One has to keep in mind this engine is free.
                    67 Series II
                    93 D110 NAS 327
                    • albersj51
                      • May 2010
                      • 687
                      Pm sent
                      • SGS714
                        • Jan 2007
                        • 83
                        for those that were interested in the head...there is a 8:1 on ebay(I am not the seller nor do I know seller) no bids $25.00.
                        67 Series II
                        93 D110 NAS 327
                        • JackIIA
                          • Dec 2008
                          • 498
                          Scott - PM'd you.
                          1970 88 IIA
                          • printjunky
                            • 325
                            Wish I'd seen this earlier!
                            If you still have the motor, I'm very interested. I'm not too far away (the Quad Cities) so I could get down and grab it pretty easily, and I have an SIII with a cracked block that I need to start looking at replacing (crack is "just" in a water jacket, and is repaired with JB Weld (and holding so far), but I don't expect it to last forever.) Ironically I also need a carb (see my posts for all the drama) and have been looking on ebay for the right Rochester at the right price.
                            Thanks,
                            Shawn
                            • JackIIA
                              • Dec 2008
                              • 498
                              Shawn - FYI. Scott generously came through for me on the engine. I'd think you can source another locally, but if not, PM me. I was talking to a guy out here about an engine he wants to sell. No idea on pricing though.
                              1970 88 IIA
